20 Most Recent
LG 60pk200 60 1080p Plasma Tv 60pk200 Questions & Answers
Picture not sharp
What are you running for a signal. Are you putting a digital signal into an anolog tv? Are you coming out of a cable box?
I am trying to play my game. When I plug
The input is not "seeing" the signal from your game---try another input and make sure connections are correct and the set is switched to the input you hooked up to(they are labeled on the back)
I have a LG dvd
player 5083 inserted the disc the correct way into the draw but the machine does not play the disc a very slight humming noise is heard then it spits the drawer back out
Clean the Lens: Use a DVD cleaning disc to clean the lens. If the problem persists, consider professional cleaning.
Test Other Discs: Try playing different DVDs to see if the issue occurs consistently. If it's specific to one disc, that disc might be the problem.
Check for Updates: Make sure your DVD player's firmware is updated. Refer to the manufacturer's instructions for firmware updates.
Try a Different TV: Connect your DVD player to a different TV to see if the noise disappears. If it does, the issue might be with your TV.
The hum is simply the player trying to read the disc. It can't so, it spits it out.
Remember that prolonged use of a malfunctioning DVD player could potentially cause damage. If the problem persists, consider seeking professional repair or replacement
