20 Most Recent Uniden TCX905 Cordless Expansion Handset Questions & Answers
My voice isnt heard
We thank you for being a loyal customer. Please note this model has been discontinued for more than 2 years and unfortunately, troubleshooting and/or parts are no longer available. We apologize for any inconvenience this may cause you.
6/30/2015 8:15:33 PM • Uniden TCX905... • Answered on Jun 30, 2015
UNIDEN tcx905 reregister failed
1 (800) 297-1023 www.uniden.com/contactus/page/contactus
6/30/2014 7:45:03 PM • Uniden TCX905... • Answered on Jun 30, 2014
0answers
How?
Be the first to answer 6/9/2014 8:17:33 PM • Uniden TCX905... • Posted on Jun 09, 2014Be the first to answer
Uniden TCX 905 Cordless phones. Nav Key has
call your provider or buy new phone
12/6/2013 10:25:28 PM • Uniden TCX905... • Answered on Dec 06, 2013
I dont know how to change phone language to
Just learn whatever language it is set to, it will delay the onset of dementia. Serbo-Croatian is a wonderful language!
11/4/2013 8:31:25 PM • Uniden TCX905... • Answered on Nov 04, 2013
Nav key stopped working
I had the same problem until today. This is what I did:
I opened up the handset and took most of it apart:
There are 2 screws in the battery compartment and you have to push something in on the sides to pull it apart. It won't come completely apart because there are wires connecting to the speaker. There are 5 screws on the inside that hold the board to the phone. I unscrewed those. The buttons are all on 1 rubber sheet. The problem is that the 4 metal connectors under the 4 way button (not on the board, the ones on the back of the rubber) have somehow deteriorated. To fix it I glued a very small piece of tin foil (I used a really thin brand) to each of the 4 connectors. They have to be done separately and the foil can't be too thick or the foil will be touching the board without a button press (found this out the hard way). Test it before tightening the screws to make sure everything worked and then put it back together.
Note: You may need to ground yourself so static electricity doesn't fry the board. If it breaks the phone, don't blame me :) I went this route because it was either play around to find a solution or buy a new phone. I don't know how long this will work for, but I hit all the buttons a bunch of times and they all work.
7/27/2012 4:05:57 PM • Uniden TCX905... • Answered on Jul 27, 2012
0answers
7answers
Uniden handset TCX905 with base unit TRU8866-if compatible?
I just successfully registered 4 TCX905s with my TRU8865 base - it's documented in the TCX905 manual.
Be sure the handset you want to register is fully charged.
Remove the handset you want to register from its charger.
Now unplug the AC for the main base, hold down the 'find handset' key on the base and plug the AC in again, when it beeps, you can let go of that button.
Hold down the '#' on the handset you want to register, it will show 'Registering Handset...' and when it beeps, it's done - registered, you're good to go :)
5/19/2012 12:47:01 AM • Uniden TCX905... • Answered on May 19, 2012
How to find a handset phone?
Just use the pager button on the base and listen for the ring on the phone. It will either beep or ring. If it is like mine you will have walked by it several times at least.
3/23/2010 9:41:00 AM • Uniden TCX905... • Answered on Mar 23, 2010
How to remove Uniden handset from base
The brillian people at Uniden don't feel it necessary to provide this type information in their manuals. You have to trial and error to find it, but what can you do. All you have to do to reset the base unit itself is to unplug the power, then while holding down the delete key, plug it back in. Hold the delete button down until you hear a beep, which indicates it has reset. Now you can readd handsets and they will start at 1.
6/27/2009 1:19:02 AM • Uniden TCX905... • Answered on Jun 27, 2009
ELBT595 & TCX905 compatibility
from uniden regarding your base station:
"This expandable base system is compatible with Uniden handset models ELX500, TCX400, TCX440, and TCX805. However, only the ELX500 is compatible the base system's Bluetooth and CellLink features."
1/5/2009 4:38:00 PM • Uniden TCX905... • Answered on Jan 05, 2009
Language
go to settings /phone settings/language and change it to french
1/28/2008 11:41:16 AM • Uniden TCX905... • Answered on Jan 28, 2008
Phone message on display
Go to Uniden.com for manual for your base model (pdf format), and you can read the instructions for registration.
10/27/2007 7:23:47 PM • Uniden TCX905... • Answered on Oct 27, 2007
I have a 88 message on my uniden power max 5.8, model tru9480-3. can i get rid of that if the base is not in service.
Page 61 from the Base Unit, there is Delete All. From the handset you have to delete 1 at a time. With.the.phone.in.standby, .press.[ ].to. delete.all.messages..When.the.answering machine asks you to confirm, press [ ].delete again..All messages are. permanently.deleted. https://www.manualslib.com/manual/184807/Uniden-Tru9480-Series.html?page=61#manual ..
12/29/2023 1:04:31 AM • Uniden Lands... • Answered on Dec 29, 2023
I have a UNIDEN AS 8116-2 phone, I have lost the user manual. I need to know how to change handset 2 to handset 1 for UNIDEN AS 8116 phone
Uniden Support - Downloads and Manuals
uniden.info https://www.uniden.info > download Uniden Support - Downloads and Manuals. Missing: 8116-2 ‎' Must include: 8116-2
6/16/2023 4:25:25 AM • Uniden Lands... • Answered on Jun 16, 2023
Uniden EZX290 Expansion Handset Fails Registration to Uniden D1660 Base Unit
Unfortunately, handsets are not universal for Uniden cordless phone systems. The accessory handset for the EZX290 is compatible with the DECT1500, 2000, 2100, 300 and 2900 DECT 6.0 phone systems. The accessory handset for the D1660 is here: https://www.amazon.com/Uniden-D1660-DECT6-0-Cordless-Handset/dp/B004NEUIY2 . I wish that I had better news for you. Unfortunately, the two systems (EZX290 and D1660) don't use same handshake codes. Cindy Wells
5/2/2023 9:42:31 PM • Uniden Lands... • Answered on May 02, 2023
Can I add another uniden hand set to a uniden D1680 series
The Uniden D-1680 system can have up to 12 handsets registered to the base. (The phone system was sold in bundles with 0 to 11 accessory handsets.) However, this cordless phone system has been discontinued. I can only find used DCX160 handsets (the compatible accessory handset) on Amazon and E-bay. I hope this helps. Cindy Wells
3/1/2023 1:07:49 AM • Uniden Lands... • Answered on Mar 01, 2023
Uniden TCX905 Cordless Expansion Handset Logo
27 questions posted
Top Uniden Lands Phones Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
View Most Popular
Uniden Lands Phones
  • Uniden Lands Phones
Most Popular Question
find handset phone
  • Lands Phones
