20 Most Recent
Panasonic KX-TG4500 Phone Questions & Answers
Line 1 stopped ringing. The
To program the ringing on the cordless handsets:
1 Press {MENU}.
2 Scroll to “Ringer setting” by
pressing {V} or {^}, then press .
3 Scroll to “Ringer volume” by pressing
L The current volume is displayed.
4 Press {V} or {^} to set the volume.
L Each time you press {V} or {^}, the
volume will alter and the chosen volume
will sound.
L To turn the ringer off, press {V}
repeatedly until “Ringer off?” is
displayed.
5 Press .
L Confirmation tone is heard.
12/3/2020 9:35:23 PM •
Panasonic...
Answered
on Dec 03, 2020
There is now no ring associated with incoming calls on line 3, but otherwise that line functions for both incoming and outgoing calls
http://service.us.panasonic.com/OPERMANPDF/KXTG4500B.PDF
page 80,do this first,
then if you want to reset both phone and base,
clear base unit settings to default,
1 Press {MENU}. 2 Scroll to "Initial setting" by pressing {<} or {>}, then press {ENTER}. 3 Scroll to "Initialize base" by pressing {<} or {>}, then press {ENTER}. 4 Scroll to "Clear settings" by pressing {<} or {>}, then press {ENTER}. L The "Clear settings?" screen is displayed. 5 Press {CLEAR}. L Confirmation tone is heard.
clear handset to default,
Press {MENU}. 2 Scroll to "Initial setting" by pressing {V} or {^}, then press . 3 Scroll to "Initialize HS" by pressing {V} or {^}, then press . 4 Scroll to "Clear settings" by pressing {V} or {^}, then press . L The "Clear settings?" screen is displayed. 5 Press . L Confirmation tone is heard.
4/11/2015 10:01:56 AM •
Panasonic...
Answered
on Apr 11, 2015
Message light blinking messages
You have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
11/26/2014 5:40:27 PM •
Panasonic...
Answered
on Nov 26, 2014
What does a boken dialling tone on my phone mean? It is all working fine and there are no warning messages on the display.
Usually broken dial tone means the line has call-forward set. You get broken tone for 3 or 4 seconds, then goes back to normal. Are you receiving incoming calls normally? It's common to set or cancel 'cause the code might kinda match a number you use. And it may be forwarded to nowhere, example, you dial 729-1111, but press 72#-1111. You might be forwarded to 1111, the code being 72#. The 1111 goes nowhere, someone calls you, calls gets forwarded, then they get a message"that number does not exist". If that's the code for your area, then 73# might be the cancel code. Check the front of the original phone book, or Google codes for your service provider.
6/14/2014 6:04:44 AM •
Panasonic...
Answered
on Jun 14, 2014
2 LINES PICK UP ON PANASONIC KX-TG4500
Sounds like you have the cords into the back of the phone mixed up. If you have a cord with 1 and 2 plugged into 1/2, great. But then if you have another jack also with 1 and 2, but plug it into 3/4, now you answer line 3 on second phone and line 1 lights up on first phone. Or line rings line 1 here and line 3 over ther. Gotta keep that straight and the jacks have to have identical lines.
5/7/2014 3:41:49 AM •
Panasonic...
Answered
on May 07, 2014
