20 Most Recent HP Compaq dc7600 Convertible Minitower PC Desktop Questions & Answers
Hp motherboard
dc7600 what case form factor is it?, CMT, SFF, USDT?what is the mobo tag Part number this?Dc7600 Tower System Board 375376-001??????????.... from the year 2005, now 14 years old,the SFF board is totally different.HP DC7600 SFF Motherboard Socket 775 MODEL 381028-001and unstated,here is my HP scan there.,for you, and hits.next is betterhttps://h30434.www3.hp.com/t5/forums/searchpage/tab/message?q=dc7600see that? at HP ACTUAL.
5/16/2019 1:40:35 PM • HP Compaq dc7600... • Answered on May 16, 2019
Pana una pregunta mi compu tienen 4 ranura y yo le
why not post in English , you can see this forum is in English. Santa said, you stated: (commented) One question, my computer has 4 slots(mem) and I put 1 GB in each slot is this model DDR2-800MHZ-CL8 PC6400U. the question, if? the computer presented a problem with time? (memory speed wrong?) to do this and the last I would like to know what video card? I can put it and how much mega(bytes) can the computer scare? me. -------------------------------------------------------------------- dc7600 (12 years old) NO OS stated. (XP,VISTA, W7/8/10) 1st came with w2000 you posted to dc7600 Convertible Minitower PC Desktop , Pentium 4 at best. 800 MHz front side bus. Dual-channel DDR2 667 memory. 4GB max ! if this is correct, (most are not, due to lack of fixya variants) then. PCI Express™ x16 , slot. the spec page says it has this slot. so most new video cards will run in this slot but not over 75watts unless the PSU is upgraded for powerful fast GPU cards with its own power cable. when new this card was an option over a decade ago ATI RADEON X300 SE PCI Express 128-MB DDR single head DVI with TV out they offered 4 vidoe card choices then. the PSU is 364watts. (marginal for any fast new Video cards) simple answers:
  1. only you memory seller can match up correct memory types DDR-667 or faster. like Kingston, as them !!!
  2. 4GB max mem.
  3. lacking correct PSU only 75watt Video cards work or less.
  4. with correct PSU the sky's the limit,!!! on power.
why upgrade such and old 12 year old system. are you dreaming of running fast $60 games? it wont work. it's too old. tell why you need the video card first?. usage matters first.
12/23/2017 1:41:35 PM • HP Compaq dc7600... • Answered on Dec 23, 2017
The Bios sees my new SATA 750GB HDD but shows it as 0GB in Size and no options to format. XP does not see the drive. How do I format it from the BIOS Setup Menu? It is connected correctly.
so what is the 1st drive, and is it IDE or SATA. or is one a why are you using XP is it 32bit or 64? ill answer for 32.. its a dead OS,totally dead,and virus magnet and the MS PnP severs are shut down. XP also MUST have the SP3 installed or the THING cant find any modern, SATA chips and many other devices. im looking at your MOBO now, it has 4 sata jacks 1 floppy and 1 IDE jack let me guess this is what Drive one, IDE (pata) is plugged in , then you add a new sata drive to the old sata ports and XP pukesssss, as all XP does (cept mine) SSDD. Same stuff different day, so you can either use w7 like all savvy folks do or find the driver missing that MS cant find, XP is dead. but wait XP needs a Floppy drive to load the correct driver. but if XP is running now, we dont need that only on XP installs. ive no idea on what sata chip is there, in our shop we scan it to find that and HP does not tell this. Pentium D processor Intel 945G Express i think this is it , the 945G load this driver from HP https://support.hp.com/us-en/drivers/selfservice/hp-compaq-dc7600-convertible-minitower-pc/472276 32bit File name: sp38488.exe (2.0 MB)
11/16/2017 9:39:21 PM • HP Compaq dc7600... • Answered on Nov 16, 2017
Hi, I want to change the
WHY BOTHER ? , why risk bricking it.?why not ask HP how to do that, (fixya is not HPi think you are like 1 , in 1billion owners doing this.?but is done by value added PC re-sellers, and is covered in the HP books. (if lucky some are not;.)here is HP real, ask them?https://h30434.www3.hp.com/ ftp://ftp.hp.com/pub/softpaq/sp58001-58500/sp58176.htmlhttps://h30434.www3.hp.com/t5/forums/searchpage/tab/message?q=+HP+Ereplogo+Utility+&collapse_discussion=trueeRepLogo.efi tool to modify boot logoask HP IF your PC can do this.first.always ask first, not brick the BIOS ,that be bad.
10/21/2017 2:26:33 PM • HP Compaq dc7600... • Answered on Oct 21, 2017
1796 sata cabling error
Make sure your Sata connection start from Sata 0 and on up. You'll get the 1796 error when you have sata drives or devices plugged in other sata connections, Like: Your first Hard drive in sata 0 your second drive in sata 1 your optic drive in sata 2....You system (BIOS) will automatically start at sata 0 then sata 1 and so fourth. hope this helps ya and thank you for using FixYa. If you need further help, I’m available over the phone at https://www.6ya.com/expert/william_02fc2766c1e13b73
10/8/2017 6:03:06 PM • HP Compaq dc7600... • Answered on Oct 08, 2017
4answers
I have 5 gigs of ddr2 ram installed its shows i have 3.5 gigs is there a jumper i can change so it reads the other ram ?if i look in dxdiag it shows the full 5 gigs installed.in system information its
http://support.hp.com/us-en/product/HP-Compaq-dc7600-Desktop-PC-series/472276/model/472278/document/c01682745/ Go to this page and make sure you have matched pairs of memory preferably all the same size and speed.
10/5/2017 1:36:46 PM • HP Compaq dc7600... • Answered on Oct 05, 2017
HP Compaq dc7600 Convertible Minitower ram support
old post , from dead file via SPAMMER.p4 processor is a dog ,not 64bitand 4gig max, 3.5g actually with XP or Vista SEE PAGE 50, FoUR 1GIG STICKS IS MAX http://h20566.www2.hp.com/portal/site/hpsc/template.PAGE/action.process/public/psi/manualsDisplay/?sp4ts.oid=472276&javax.portlet.action=true&spf_p.tpst=psiContentDisplay&javax.portlet.begCacheTok=com.vignette.cachetoken&spf_p.prp_psiContentDisplay=wsrp-interactionState%3DdocId%253Demr_na-c00383428%257CdocLocale%253Den_US&javax.portlet.endCacheTok=com.vignette.cachetoken let me guess, 1gb now and want 44 will only give you 3.5g. win 3b2 limits.ddr2-x4dybgm1xaxinyj1r3jreevk-5-0.jpg
2/21/2017 3:09:24 PM • HP Compaq dc7600... • Answered on Feb 21, 2017
2answers
Installed a new e5300 2.6ghz dual core cpu on my
check the bios settings...if onboard video is enabled or not....
if this does not solve the problem...try to replace the psu...with a good psu from corsair...
this might help...post your further queries
9/4/2015 5:46:02 PM • HP Compaq dc7600... • Answered on Sep 04, 2015
How to know ur power on password..my pc ask for this thing
See page 2 - "Disabling or Clearing the Power-On and Setup Passwords" http://h20565.www2.hp.com/hpsc/doc/public/display?docId=emr_na-c00404245
8/11/2015 6:59:19 AM • HP Compaq dc7600... • Answered on Aug 11, 2015
How to reload the BOIS on hp compaq desktop
download from hp site and install on pc
5/5/2014 9:43:19 AM • HP Compaq dc7600... • Answered on May 05, 2014
Audio wiring problem on HP Compaq DC7100 CMT with DC7700 motherboard
You have a problem with HP connectivity. When I moved my dx7100 motherbard into another casing I experienced that error and also chassis fan not detected error. Chassis fan error is easy to remove, You only need a fan with at least 3 cables (with sensor) and plug it into 4 pin chassis fan connector. Audio conector have 10 pins (eight pin missing for orientation (with followed numerication2 4 6 101 3 5 7 9If you only want to get rid of the error ( with no use of back audio(use of another soundcard)) then short pins 2 and 7. But if you want to use back connectors, then you must bridge with jumpers 1-3 for microfone, 5-6 for audio L and 9-10 for audio R.I've bee searched thru internet and didn't find this trick anywere.
12/8/2013 2:42:22 PM • HP Compaq dc7600... • Answered on Dec 08, 2013
0answers
Front panel microphone pin notworking
Is it plugged in to the motherboard? Does the rear one work?
9/7/2013 4:28:53 PM • HP Compaq dc7600... • Answered on Sep 07, 2013
0answers
Hola tengo un problema tengo una HP Compaq dc7600
Usted no puede mezclar la memoria entre los dos sistemas. Son incompatibles.
6/2/2013 6:31:46 AM • HP Compaq dc7600... • Answered on Jun 02, 2013
I reinstalled windows xp on my hp dc7600 small form desktop unfortunately i have lost my network adapter driver so i cannot access the internet to fix this problem however i do have accesss to another
You will have to open up your network connections. Click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark you will need to update or install the driver or it could be firewalled. Click start control panel administration tools computer management device manager look for network adapters + expand Ethernet driver if you see a yellow Question / Exclamation mark ? ! or a Red X you will need to update/reinstall the driver for the device You only need check the following if you cant install the driver Make sure you Ethernet/internet is enabled in bios. Restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys scroll to intergrated peripherals look for SiS On Chip Pci Device press Enter make sure its enabled then recheck the driveri t should be there k the driver it should be there make sure its enabledPci device arrows key scroll to nstalled if you computer came with a motherboard disk the driver could be on it or this disk provided by your ISP provider Internet Service Provider or you might have to download one http://download.cnet.com/wireless-atheros-ar5b91-7/3000-2112_4-202570.html http://download.cnet.com/Realtek-RTL8139-Family-PCI-Fast-Ethernet-NIC/3000-2112_4-91313.html
3/3/2013 11:40:10 PM • HP Compaq dc7600... • Answered on Mar 03, 2013
HP Compaq dc7600 Convertible Minitower PC Desktop Logo
109 questions posted
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
dc HP
  • dc HP
Most Popular Question
audio wiring problem hp compaq dc7100
  • Computers & Internet
