20 Most Recent HP Pavilion a810n (PP164AA) PC Desktop Questions & Answers
3answers
Blinking green light, will not power on
This is an easy fix so here you go nice and simple: Problem: Your motherboard circuit has been cut. Causes: Power disconnected during operation. Power outage or short in the surge protector. Symptoms: Flashing green light on both motherboard and power supply. System will not power on. Solution: Step 1: Ensure that both the power supply and the motherboard lights are flashing green, not solid or off. Step 2: While the power is on, disconnect the power supply from the motherboard. This connection is the largest of the connections and should be listed as the 'P1' or 'Primary' power connection. Step 3: Wait until the green light on the motherboard stops flashing and check to ensure that the green light on the power supply is now solid. If it is not solid, disconnect the power to the power supply and wait until the light turns off completely. Then reconnect, it should be solid now. Step 4: While the power is on, reconnect the P1 connection to the motherboard and you should now see that the light on the motherboard is solid. Step 5: Power on your PC. The problem should not persist. Warnings: If the power supply light remains flashing after you have restored power to it while it is disconnected from the motherboard, it may be a system failure in the power supply itself requiring replacement. Always be careful when working with an active or live power machine. And much more details : http://www.hptechsupportphonenumber.com/
12/11/2017 9:43:02 AM • HP Pavilion... • Answered on Dec 11, 2017
Where can I find a diagram of the inside of a Pavilion 511w?
You don't need a diagram of the inside to reload the OS.
7/25/2014 9:04:11 PM • HP Pavilion... • Answered on Jul 25, 2014
Monitor reads: PC entering power saving mode then shuts off;PC on
First do not take the hard drive out and put it in another computer. It is configured to run in the computer it's in.
Next, you probably did have a power surge either from your power supply or the power in your home. It sounds now like your power supply is damaged.
The processor does not have any gears; the sound you hear is most likely the fan in the power supply running too high.
Taking the battery out does nothing unless you move the jumper on the rtc to clear the CMOS. You should do that. You will have to get the computer running before you can transfer via USB to a flashdrive.
Unless you know what you are doing, you can ruin your computer just by touching components or the motherboard. You need to ground yourself first and make sure the computer is unplugged from the wall.
Here is what I recommend:
1. Get a grounding strap and hook it to your wrist and something to ground it. The package will tell you how.
2. Open the computer case and move the jumper to the proper location to drain the CMOS. (There will be 3 pins, and it will be on two of them. To ground it move the jumper to the uncovered pin and the one next to it. Leave it there a minute then remove it and out it back on the other two.
3. Be certain the two sticks of ram are properly inserted all the way in the slots; do not use brute strength.Leave the side cover off, and plug the Computer back in again. You should see a light come on after a few seconds. You should also see the power supply fan on.
4. Turn on your monitor and then boot your computer. If it comes to a screen that says it stopped abnormally, choose the last known good configuration.
5. you don't get that far you have worse problems, namely the motherboard or the powersupply. If it boots you should also hear the hard drive whirring.
If you can't get it going let us know. But one thing I'd like to convey to you. There is nothing in your conputer any reputable technician in a good shop will want. Neither will he put malware on your system.
Sirwriter
6/25/2014 12:19:48 PM • HP Pavilion... • Answered on Jun 25, 2014
3answers
How do I factory restore
HP provided recovery disks. If you don't have them, you can get them from this site.
http://www.myrecoverycds.com/HPa800.html
If this answers your question, I'd appreciate 4 thumbs. I do this for fun and do not get paid.
Jim
9/6/2012 12:03:52 PM • HP Pavilion... • Answered on Sep 06, 2012
I cant watch a video on windows media player
Please check the format of that video file or download VLC player its good and supports all the Video format
9/4/2012 6:18:31 AM • HP Pavilion... • Answered on Sep 04, 2012
HP Pavilion a810n green light flashing but won't power on
it sounds like power supply problem
8/8/2012 7:04:07 AM • HP Pavilion... • Answered on Aug 08, 2012
Hp pavilion a810e will not power up.
if you look inside and the led lights are on in your motherboard it means your motherboard could be fried and not to state the obvious check your front power wire is attached to the inside of your casing power on switch
8/6/2012 12:19:47 AM • HP Pavilion... • Answered on Aug 06, 2012
5answers
Pc entering power save mode
I am having the same problem . The system is starting up and th epc entering power save mode. I have a Hp pavilion f1503 model monitor. I hit the power off button on the power surge to shut the entire power off. I turn the power surge button back on. Sometimes it works. Or have to hit the power on button to reboot.
8/4/2012 11:03:56 AM • HP Pavilion... • Answered on Aug 04, 2012
Doesn't read any sd or others cards
Check the device manager to see if the card reader is there. Or go to the manufacturers site (HP in your case) and download and install the driver for the reader.Get online and go to www.google.com In the google search box type: "HP Support" (without the quotes). Look for downloads and drivers. Enter your model number and operating system when requested. Download and install the drivers.You can always buy a reader for under $15 at computer shops that plugs into the USB Port.
4/3/2012 12:34:48 PM • HP Pavilion... • Answered on Apr 03, 2012
Why doesn't read any sd, md cards
Check the device manager to see if the card reader is there. Or go to the manufacturers site (HP in your case) and download and install the driver for the reader.Get onlineand got to www.google.com In the google search box type: "HPSupport" (without the quotes). Look for downloads and drivers. Enter your model number and operating system when requested. Download andinstall the drivers.You can always buy a reader for under $15 at computer shops that plugs into the USB Port.
4/3/2012 12:32:51 PM • HP Pavilion... • Answered on Apr 03, 2012
2answers
Last week my HP Pavillion
No, the southbridge simply is no longer working properly - the PATA controller to which the optical drives are connected has failed. The motherboard is dead, you must replace it.
9/11/2011 10:29:10 PM • HP Pavilion... • Answered on Sep 11, 2011
I have windows XP and
Well i recommend you reinstalling windows xp
9/1/2011 5:57:25 AM • HP Pavilion... • Answered on Sep 01, 2011
I have a soild yellow
That is the HDD light or the hard drive activity light. There must be something accessing your hard drive. Is there a problem with the PC like slow speed or booting?
8/28/2011 9:14:50 PM • HP Pavilion... • Answered on Aug 28, 2011
During starting i get one
Hello axel,
Before addressing the beep code, please unhook any devices you have plugged into the computer, such as printer, scanner, camera. Then try starting it.
According to hp that beep code is associated with a cd/dvd burner issue. Open up the computer, and pull the power cord out of it. While you have the case open, clean out any dust that is inside, overheating may be causing the issue. Place cover back on, and try starting it.
Next step is to reseat the hardware inside your computer, this involves removing components such as memory, video card(if present), and any additional hardware you may have.
Next remove extra hardware, If it is non-essential try starting your computer without it being installed.
including a link to common beep codes to use as a reference, They will change depending on the hardware you remove, such as memory, video, and the processor.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=bph07107#N196
8/19/2011 2:46:50 AM • HP Pavilion... • Answered on Aug 19, 2011
2answers
Replacing power supply to hp
The secret: all the wires are oriented (you cannot plug the in backward), and your replacement
power supply must have a connector for each of your peripherals.
Even the connector going to the motherboard is oriented.
Make sure everything on this list has a power connector plugged into it, then
power up the desktop system and compute.
1. motherboard
NOTE: everything below in the list resides in a peripheral bay
2. HDD (hard disk drive) (there may be several)
3. FDD (floppy disk drive)
4. CD-ROM
5. DVD-ROM
If you run out of connectors, buy a "Y-connector" at your local "Computer Goodies" store.
As you connect these devices try to utilize proper anti-statis techniques - meaning, if you don't have an anti-static strap to clip onto the Pavilion A810N frame, then be sure to ground yourself
by touching the frame with a forearm or something as you make/unmake the power connections,
while at the same time try to avoid touching the (CMOS-based) IC chips or PC board surfaces.
forearm
External drives (incl tape drives) get their own power - not from your 400W Dynex.
Your computer monitor will also gets its own power (from a 120VAC 3-prong CEE cord)
3/18/2011 8:59:32 PM • HP Pavilion... • Answered on Mar 18, 2011
When printing from the internet or email, page is
Which browser do you use?(firefox,internet explorer)
Example:Firefox will spool to your printer system, particularly to the default printer.
2/9/2011 8:23:35 PM • HP Pavilion... • Answered on Feb 09, 2011
2answers
My computer no longer "sees"
hello
at end of this instruction set, see link to review more questions/answers,as your issue with CD/DVD ROM will vary .
This document applies to HP and Compaq desktop computers with Windows XP, Me, and 98. Use this document to make Windows and the CD writing software recognize the CD or DVD writer drive. Start at Step 1; do not skip to other sections until Step 1 has been completed. Step 1: Does Windows detect the CD or DVD drive? Use Device Manager to determine if Windows is recognizing the drive:
  1. In Windows XP, click Start , and right-click My Computer . In Windows 98 and Me, right-click the My Computer icon on the desktop.
  2. In Windows XP, select Properties , click the Hardware tab, and then click the Device Manager button. In Windows 98 and Me, select Properties , and click the Device Manager tab.
  3. Click the plus sign (+ ) next to DVD/CD-ROM Drives (or similar) category.
  4. Do the following depending on what is listed in the DVD/CD-ROM drives category:
    • If the CD or DVD drive name is missing , the drive is not being detected by Windows. Close Device Manager and skip to the section CD or DVD drive is not recognized by Windows .
    • If a drive name is shown but is disabled (icon is marked with a red X, c00877300.gif ), the drive has been disabled. Right-click the drive name and select Enable . You may have to restart the computer to complete the enabling process. The drive should work correctly once it has been enabled. NOTE: If the drive cannot be enabled, a required service or driver that the drive needs is not functioning or has been disabled. Click the plus sign next to IDE ATA/ATAPI controllers and troubleshoot any problems found according to any error codes in Device Manager. Resetting the BIOS may also resolve this problem.
    • If a drive name is shown but contains an alert icon (an icon marked with an alert symbol, c00877301.gif ), then use the section Using Device Manager error codes to troubleshoot the problem. You may also use the next section Disc burning software does not recognize the original drive to reset the drive configuration.
    • If the CD or DVD drive is listed as normal but your disc burning software does not recognize the drive, Device Manager shows no special icons c00877302.gif . Windows is detecting the drive but the writing software does not. Leave Device Manager open and continue with the next section Disc burning software does not recognize the original drive .
here is a link that will give you several other questions and answers to CD/DVD ROM issues.
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?tmp_rule=11843&tmp_task=solveCategory&lc=en&dlc=en&cc=ca&lang=en&product=443069
please rate me with 4 thumbs UP to keep my services active
12/1/2010 3:13:34 AM • HP Pavilion... • Answered on Dec 01, 2010
I have an HP a810n
Hi There,.
I recommend you work your way through this guide before attempting file transfer.
http://pcsupport.about.com/od/findbyerrormessage/a/stop0x0000007b.htm
The best way to recover the data you want is to remove the drive, install it in an external enclosure and read the file from another computer, saving them to flash drive or another external storage drive.
Regards,
Marcus
9/17/2010 1:54:52 PM • HP Pavilion... • Answered on Sep 17, 2010
CORE2DUO PROCESSOR,WINDOWS 7.WHEN I PLAY
ropar_mbl
The link below will help you change your sleep mode setting. Note you may need to go into the advanced options.
http://www.fixya.com/support/r5720930-change_monitor_computer_sleep_time_in
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
9/8/2010 9:18:37 AM • HP Pavilion... • Answered on Sep 08, 2010
I have a HP Pavillion
Try to F8 it into safe mode and check the device manager for conflicts. It is probably a device driver issue. It is a matter of finding the problematic device and then working toward a solution.
9/2/2010 8:20:02 PM • HP Pavilion... • Answered on Sep 02, 2010
HP Pavilion a810n (PP164AA) PC Desktop Logo
64 questions posted
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Pavilion HP
  • Pavilion HP
Most Popular Question
blinking green light will not power
  • Computers & Internet
