20 Most Recent Epson TM-T88III Thermal Printer Questions & Answers
2answers
Driver urgent
Epson website, download what you need
12/23/2022 5:00:14 AM • Epson TM-T88III... • Answered on Dec 23, 2022
4answers
Epson TM-T88#P thermal printer driver for windoze vista
You can use windows 2000 drivers on Vista for this printer, according to this article:
http://www.prophetline.com/node/141
11/6/2021 7:48:34 PM • Epson TM-T88III... • Answered on Nov 06, 2021
tip
Printer : Checking the printer
Check the lights on the printer
Power in solid green - printer is in ready mode, else:
  • disconnect and try another power source or power-adapter.
Paper Feed in solid red - no paper:
  • make sure paper is of the correct type and dimension. re-seat the paper.
Error in solid or flashing - hardware problem:
  • turn off the printer.
  • open and access the DIP switches, make note of the current settings, then set it all to zero.
  • remove the Connect-It module at the back and re-install it.
To test the printer do the following:
1. Disconnect the printer from the computer.
2. Turn the printer off. Make sure that there is paper and properly loaded.
3. Press and hold the Paper Feed button while turning the printer back on.
4. A self-test print-out that contains information such as firmware version and settings depending on the detected connection type.
0answers
Epson TM T88iii printer not printing
Since you are using the USB-to-serial converter, you need to select the serial interface in the printer driver installation.
  1. Uninstall the driver in Control Panel > Add or remove programs
  2. Restart the computer
  3. Install the printer driver again, this time select serial in the interface list
  4. Set the properties for the serial port to 9600 for the data rate
  5. Print a test page!
9/7/2017 7:29:58 AM • Epson TM-T88III... • Answered on Sep 07, 2017
4answers
How to auto tear paper after printing receipt is completed.
moz-screenshot-2.jpgIf you are using the generic driver you can get the code from epsonexpert.com site or try this
SELECT CUT MODE AND CUT PAPER ASCII GS V m
executes full or partial cut. HEX 1D 56 m
DEC 29 86 m
m = 0, 1, 48 or 49 cuts paper
SELECT CUT MODE AND CUT PAPER ASCII GS V m n
feeds paper and executes full or partial cut. HEX 1D 56 m n
DEC 29 86 m n
m = 65 or 66 feeds paper to (cut position + [n x (vertical motion unit)]) and cuts the paper
n = 0 to 255
8f9f602.tif
7/3/2016 10:35:02 AM • Epson TM-T88III... • Answered on Jul 03, 2016
2answers
I need the printer driver
You can try downloading from this site which requests you provide your e-mail address or you might prefer to send a request for the driver directly to the manufacturer.
See here for details on your printer:
http://www.epson.com.au/businesssystems/products/receiptprinters/DisplaySpecs.asp?id=tmt88iii
Click on Technical & Support along the top menu bar. This will bring up a submission form which you can use to submit a request to provide a driver for your printer.
7/1/2016 2:41:23 PM • Epson TM-T88III... • Answered on Jul 01, 2016
4answers
It has stopped printing. Green light is still on, however it stopped printing receipts out of no where.
reinstall the driver on your pc. if it doesn't help maybe the port connection board is not working correctly.
8/12/2015 2:40:14 PM • Epson TM-T88III... • Answered on Aug 12, 2015
This printer keeps cutting, its the circuit. which is the component on the main board that I need to replace.
If it is a USB printer then try replacing the USB cable. Otherwise also try changing the power cord.
If the cords are ok then try upgrading the printer driver. You can find it on the relevant company's website.
3/19/2015 9:08:24 AM • Epson TM-T88III... • Answered on Mar 19, 2015
How do I fill up the ink on my Epsom TM-T81?
Hi, there is no need for ink for this printer. it's a thermal printer, you have to use thermal paper with it.
3/6/2015 1:03:04 PM • Epson TM-T88III... • Answered on Mar 06, 2015
I have a EPSON TM-T88III running off WINDOWS 7 professional. I have upgraded from WINDOWS XP. MY CASH RECEIPT PRINTER IS NO LONGER PRINTING CORRECTLY. The printer is gone slow MY Fonts print croo
Go to Control Panel - Device Manager & find your Printer i.e. little arrow by the Imaging devices. Right click the T88 & click upgrade drivers, then clik the upper choice & it will go to Microsoft & find the correct driver for that unit & install it. (must be on line) That should solve your problem If not call Epson I’m happy to help further over the phone at https://www.6ya.com/expert/wynn_5ba0205233ebfc15
12/14/2014 4:53:35 PM • Epson TM-T88III... • Answered on Dec 14, 2014
0answers
0answers
0answers
0answers
Epson TM-T88III Thermal Printer Logo
199 questions posted
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
TM Epson
  • TM Epson
Most Popular Question
in installing old epson t88iii receipt
  • Office Equipment & Supplies
