20 Most Recent
Epson Stylus Photo RX700 All-In-One InkJet Printer Questions & Answers
The ink pads are at the end of their service life
if the ink pads at the end of their service life you need to get a new inkpads. but there are tricks for resetting it so that you wont need to replace it. just look for the model of your printer resetter. it will not bug you anymore telling to replace your ink pads. hope this helps
Scanner glass
I use warm water with a tiny bit of washing up liquid. I use a micro fibre cloth dip it in the water, wring out until vertually dry and clean the glass. Use a dry micro fibre cloth to dry. Do not use glass cleaner.
Services riquierd error
your printer is need to reset firmware, don't panic it easy to do, go to net and search ssc utility for epson and installed it to the to your computer its free, after you download and installed connect your printer to pc and run the reseter. select reset protection counter. and restart your printer, then can print
Epson RX700 printer, end of service life message
This usually means that the waste ink absorbers are full. If your printer is under warranty, you can get them dealt with and the counter reset at an Epson Customer Care center. If your printer is out of warranty, you should consider if it is worth the fix. You can get this done by Epson or an independent printer repair person. (They might sell the parts for a dyi job.)
Once that is done, you can get a reset utility from the following URL: http://www.epson.com/cgi-bin/Store/support/InkPadsForm.jsp . If you execute the reset without the pad replacement, you will get ink smearing on your documents after a while.
I hope this helps.
