20 Most Recent Dell 810 All-In-One InkJet Printer Questions & Answers
How to change printer cartridge Dell 810
Open the printer cover with it turned on and connected to your pc. When you open the cover, the printer should bring the ink cartridge carrier to the front and center so you can access cartridges easily. Press or pull the plastic tab next to the ink cartridge that you wish to replace and it will pop it up towards you and out of the carriage. if there is no plastic tab to eject the cartridge, grab a hold of it with your finger and pull upward and out towards you. Don't worry about breaking anything or harming the cartridge. Once you remove the old one, remove the plastic tape tab on the new cartridge before inserting. Then close the printer cover and it should walk you through aligning the print heads on the display. Good luck!
11/4/2019 9:37:35 AM • Dell 810... • Answered on Nov 04, 2019
3answers
Error Message "Communication Not Available
Please open the link and follow the instructions this will definately resolve the issue, and please respond with comments to impove better service and resolution
Communication Not Available" Error When Sending a Print Job
http://support.dell.com/support/topics/global.aspx/support/dsn/en/document?c=us&dl=true&docid=2AA10ED87ADC4C0EE040A68F5B285B98&journalid=45AF3C8CB5A7BDF9E040A68F272874F0&l=en&s=gen
Regards
11/4/2019 5:41:27 AM • Dell 810... • Answered on Nov 04, 2019
Will not power on.
it might be the power supply board itself ,either fuse or the condenser is burned.
4/17/2016 5:55:01 PM • Dell 810... • Answered on Apr 17, 2016
2answers
How to remove ink from printer
Ink Cartridge Maintenance
  1. Turn on your printer.
  2. Lift the printer unit, and position the scanner support between the tabs to hold it open.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
  1. Press down on the ink cartridge lever to raise the ink cartridge lid.
  1. Remove the old ink cartridge.
  1. Dispose of the old cartridge properly.
  2. If you are installing a new ink cartridge, remove the sticker and transparent tape from the back and bottom of the ink cartridge.
  1. Insert the new ink cartridge.
  1. Snap the lid closed.
  1. Lift the printer unit, and hold the scanner support up while lowering the printer unit until it is completely closed.
12/2/2015 3:42:56 PM • Dell 810... • Answered on Dec 02, 2015
PAPER JAM
When the paper goes it on the inside of the printer grabs both side which what feeds it through, if it is not tight enough will cause paper jams, open it back up and check the roller to see if it can be adjusted if it cant then you will need to buy a new one, this usualy happens when it has had too many paper jams forcing the gap to increase in size and not allow the collection of one but many, on single sheets of paper the gap wont be small enough to collect 1 sheet anymore.
7/10/2015 10:08:08 PM • Dell 810... • Answered on Jul 10, 2015
3answers
I got a new computer and it does not have the
Just copy and paste.
Hope this helps.
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=PRN_ALL_A810&os=WW1&osl=en&catid=&impid=
3/3/2015 11:31:55 AM • Dell 810... • Answered on Mar 03, 2015
0answers
0answers
3answers
Does the tell 810 all in one printer come with a usb?
Yes this printer should come with a USB cable because that's the only way you can use it , so if this unit is new better go back to the store where you purchased it and ask them about the USB cable so they can replace it....
4/19/2013 9:02:22 AM • Dell 810... • Answered on Apr 19, 2013
My printer will scan but it want print i dont think it iscorrespond with my computer
Hi Scottie here, you can fix the problem by shutdown your computer down and see if you printer fix it selp!
3/25/2013 9:02:18 PM • Dell 810... • Answered on Mar 25, 2013
Can this be used as a Stand alone Printer?
To print documents a printer need to be connected to a computer.The Dell 810 is a laptop not a All-In-One printer.
12/11/2012 9:57:23 AM • Dell 810... • Answered on Dec 11, 2012
My dell 810 all in one will scan but will not
"Turn the printer on while holding down both the ink and paper buttons. When the paper light flashes release both buttons", then hold down the ink button for approx. half a minute until the printer lights flash again then release it. That resets the printer.? PLEASE TRY NOW !
6/29/2012 7:00:48 PM • Dell 810... • Answered on Jun 29, 2012
Will not work with windows 7
Hi Loretta,Have you installed compatible[Windows 7 OS] printer drivers in your new PC?If not uninstall the already installed drivers and install new drivers from this Dell support site. Also make sure you properly connect the printer with the PC.Hope this helps.Thanks!Please rate this answer.
11/24/2011 7:03:19 PM • Dell 810... • Answered on Nov 24, 2011
Can't get the 810 printer
You can download the User guide from this WEB Site.
http://support.dell.com/support/edocs/systems/PRN810/en/index.htm
8/26/2011 11:04:18 AM • Dell 810... • Answered on Aug 26, 2011
Dell 810 All-In-One InkJet Printer Logo
197 questions posted
Top Dell Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Ngoro
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Dell Office Equipment & Supplies
Most Popular Question
will not power
  • Office Equipment & Supplies
