20 Most Recent
Konica Minolta Developer 02xk Dv710 for Bizhub 600, 601, 750, 751 Questions & Answers
C-6708 code
Does your exposure lamp come on ? Mite have a problem with the scanner lamp or the Scanner reader that the CCD the black device under the big glass that views the document to be copied. Exposure lamp is what high lights the original document(s) Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/normanj_7893313f0751935f
How can fix this code C-2105 in konica minolta bizhup 600
C - 2105 Transfer/separation corona cleaning motor home sensor error code.Remove the transfer/separator corona located in ADU assy,use the vacuum cleaner and clean the corona support and the 2 sensors(located under corona assy rear and front area).After cleaning urn ON the copier and is working.
Error code c6708
Please send me konica minolta bizhub 600 full service manual and help us this code c6708 still and my next machine bizhub 750 still warming up why problem this machine please help and send me your email address.
i want to talk to you continuous
Service call c3451
Its the error code for Fuser temperature abnormality.
You did not mention the photocopier model?
My machine bizub 600i show on screen c3503 how to remove this by which i cando
Power off the machine, using the main power switch located inside the machine. Then ensure the sub power switch is on that's the one on the control panel. Now depress the Utility/Counter button and turn on main power must keep the button depressed. once you see trouble reset touch it get a OK. Power off then wait ten seconds and power back on. If the code comes back do not reset again the machine can catch on fire and that will ruin a perfectly good day. get a technician to look at it The Fuser is not something to mess around with. Btw, I’m available to help over the phone in case u need at
Konica minolta bizhub press 1250 p c-2101
Charge cleaning assy. error. There is a very fine gold plated wire that is above the drum on the drum cart. Must be remove to be seen. Well there is cleaning device for that wire. you may hear it some time when you turn on the machine. Well its stuck or the motor (bad/Stuck) or sensor that tells the machine the cleaner is back home mite be dirty/Toner. Remove the drum cart and check it out. There is also the same system for the transfer/separation wires that are below the drum which the paper goes over as the drum transfers the image to the paper. Btw, I’m available to help over the phone in case u need at
Konica Minolta Bizhub 600 c-2101 code
C - 2101 The lock signal of the charging cleaning motor(mounted on the charge corona assembly) is not detected when a specified period of time elapses after is starts the backward operation from rear to front.Remove the drum unit and remove the charge corona and rotate manually the cleaning pad,eventualy remove the cleaning motor and verify the gears.If not reseting to Open /close the frontal door,try reset:Turn OFF the copier,keep pressed the Utility key and turn ON the copier.Wait will apaire the Trouble reset message ,release the Utility key and touch the message,then turn OFF the copier.Wait 1 minutes and turn ON.GOOD LUCK!
I have a konica Minolta bizhub 750 and its giving me error code c2401 what may be the problem
Sir/Mam, The Erase lamp is disconnected. have you had anyone recently replace the drum or developer? if so the erase lamp connection is not seated properly or you do have a bad erase lamp. You will have to remove the drum cartridge open front door life up small pipe unscrew the main nut hold nut unscrew (When screwing back in do not allow the nut to turn to the right) Any way once the cartridge is removed check two connections above the drum to the rear to small connectors (BE CAREFUL DO NOT SCRATCH OR NICK THE DRUM DO NOT EXPOSE TO SUNLIGHT) ensure the two connectors are secured! Re-install. if the code comes back you mite have a bad Erase Lamp. Contact a Technician! Btw, I’m available to help over the phone in case u need at
Check the Transfer/SEP assy. it is directly below the drum when you open the front section of the machine it will be a assy. with three very thin wires covered by a plastic guard there is cleaning device that cleans those wires when you turn on the machine. Check the drive for the cleaning motor, assy. can be removed two screws one in the front one in the back on the section you open. Motor is under the front part of the assy. Can be completely turned off via service mode soft switches. Btw, I’m available to help over the phone in case u need at
