20 Most Recent
GE 27934GE1 Twin Cordless Phone Questions & Answers
Good day to you...my handset
As Silly as it sound's ensure device is plugged in to the wall and the power is on.If both of these are ok start by a process of elimination.Disconnect device from the wall and plug into a different wall socket in a different room. If there is no change ensure land lines in your immediate area are other wise ok by asking your neighbour if their land line is on.If so ask if you can connect your unit into their phone line and wall unit.If u still aren't getting dial tone your phone unit is stuffed. If it is a brand new unit you may need to register it to the mother unit.If it a battery powered mobile it may be a flat battery or the battery has burnt out.
If hand set one works fine but not #2 after all this I would suggest you need to replace it.
Hope this helps.
Ge 25841ge3-b cordless phone
You need to put the phone on the master handset and registered it. It whould start working. Take the handset and put it into the base unit (not the chraging unit only, the base that has the keys on it) for at least 20 seconds. The user guide says it will "register" during that time.
If it does not work then there is some battery problem with your phone please service it asap.
Please follow the manual if you donot know how to register or name it:
http://dl.owneriq.net/0/0f069335-04a2-43c8-8429-718863211e46.pdf
Thankyou for contacting Fixya.
Does my phone have a mute function?
I don't think you can mute this phone. Please check out both websites. The first site is the instructions. The second is the manufacture instructions. I hope this helps. Sorry I could'nt help more.
http://157.254.235.130/public/27934_ib.pdf
http://www.thomsonnetwork.com/EN/Public/InstructionBook/IBVeritySearch.htm
I have a GE model #29893GE1-B it is connected and plugged in, but no dial tone
Remove all the phones on the system. Remove all the handset batteries. Plug in one old style corded phone to the main phone jack, it is normally the one closest to the front door. Do you have dial tone? If not, it is your Telco. If you have a dial tone, plug all the other phones in testing for a dial tone as you go.
Why is my GE washer leaking water from the right front corner?
A leak coming from the front of a front-load washer is often caused by a damaged or dirty door seal. If the door seal is cracked or loose, it will need to be replaced in order to restore a watertight seal. Always ensure all clothes pockets are empty prior to washing, as objects left in pockets can damage the door seal.
Trying to find replacement phone battery for GE model 2-9421A phone set s/n 80052268.
If you mean the long-life lithium backup battery for the corded 2-line GE 2-9421 (A indicating the sales region), that is a 3V Lithium battery. The part number 5-1923 appears to be a common CR2032 coin cell battery. These are used as backup batteries for Eraseable Programmable ROM on many devices, including computers.. One source is https://www.batteriesdirect.com/product/details/button-cell-batteries/ge/5-1923 . Any CR2032 from a reputable manufacturer will work.
I hope this helps.
