20 Most Recent Konica Minolta Minolta Di450 Di470 Di550 Copier Mt Toner 502a 8936-902 Questions & Answers
2answers
Erace the c-of24 on di450
The code refers to a sensor that looks at the drum - it might be dirty or something else is going on check this Fixya-link: Minolta DI450 error code C0F24
11/1/2021 1:03:49 PM • Konica Minolta... • Answered on Nov 01, 2021
2answers
Repair carriage wire of di450 photo copier
What carriage wire?Is 2 wire in the transfer/separator corona.Is cut change.
11/1/2021 1:02:43 PM • Konica Minolta... • Answered on Nov 01, 2021
Error Code c0045
Bop. Error Code c0045. Check the attached links,instruction and guides, Good luck "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info." http://www.officeimagingsystems.com/id169.html Konica Minolta Di450 Error Codes http://www.biz.konicaminolta.com/download/users-guide/c554e_c454e_c364e_c284e_c224e/en/contents/id16-_101076518.html
1/2/2021 5:16:25 PM • Konica Minolta... • Answered on Jan 02, 2021
C11a4
Ventilation Fan Motor's failure to turn • The Lock signal remains HIGH for a continuous period of 1.5 sec. or more after the lapse of 10
4/20/2019 12:03:40 PM • Konica Minolta... • Answered on Apr 20, 2019
C1029 di 470 error
memory board failure Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
3/11/2018 3:54:33 PM • Konica Minolta... • Answered on Mar 11, 2018
Code error c0f24
replace the drum and developer Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
3/10/2018 8:17:16 PM • Konica Minolta... • Answered on Mar 10, 2018
C 1029 di 450
3/10/2018 6:38:00 PM • Konica Minolta... • Answered on Mar 10, 2018
Minolta DI450 error code C-0920
1st paper draw lift motor is jammed or burn out or the control board is bad. Check for paper behind the draw, also remove any paper from left side of draw. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
7/4/2016 7:49:10 PM • Konica Minolta... • Answered on Jul 04, 2016
Username for scanner mode
look like the previous owner had a password for scanning , ask him Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
5/11/2016 8:33:42 PM • Konica Minolta... • Answered on May 11, 2016
Minolta 550 c0f24
replace the developer and the drum ensure the counters are cleared first and that the F8 is run after install Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1/23/2016 11:59:14 PM • Konica Minolta... • Answered on Jan 23, 2016
Di 450 constant paper jam
where is it jamming ???????????????????????/ Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1/23/2016 4:38:07 AM • Konica Minolta... • Answered on Jan 23, 2016
Spread toner on paper
what do you mean spread toner Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1/18/2016 11:07:17 PM • Konica Minolta... • Answered on Jan 18, 2016
Urn the main switch OFF and then ON following the instruction.
what are you trying to do???????????????????????/ what is the problem?????????????????????? what instruction ????????????????????????????/ Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1/15/2016 9:46:02 PM • Konica Minolta... • Answered on Jan 15, 2016
Minolta Di 450 code 13 & 14
need additional numbers codes are c-xxxxx Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1/15/2016 9:05:44 PM • Konica Minolta... • Answered on Jan 15, 2016
Does it has flash memory connector
NO!!!!!!!!!!!!!!!!!!!!!!!! legacy minolta Flash had not been desiged yet Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1/15/2016 10:32:59 AM • Konica Minolta... • Answered on Jan 15, 2016
Di 450
replace the print head, print head houses the LASER for the machine, might try this site as a start Precision Roller Printer Toner Cartridges Parts and Supplies Office... Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1/14/2016 3:38:31 AM • Konica Minolta... • Answered on Jan 14, 2016
HOW TO FIX WITH PC
Does your machine, have the print controller option? Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
5/24/2015 4:33:25 AM • Konica Minolta... • Answered on May 24, 2015
C-0072 is showing on my Konica Minolta di552 please help to remove this error
Power off the machine. Then remove the toner bottle be careful the hole might be on the bottom toner is going to go everywhere. Then close the toner cover and turn on the machine. Let the machine go through it normal routine. When it asks for toner install the toner bottle correctly. If THE KUNB on the side of the bottle is damage put a new one in that KUNB is what the toner motor uses to turn the bottle if it is damaged you get a code. If this does not work you might have a bad motor or the home sensor or actuator for the toner bottle is bad worse case the control board is bad Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
5/21/2015 12:36:13 AM • Konica Minolta... • Answered on May 21, 2015
tip
Toner Bottle Issues for the Di450/550 Copier
Power off the machine. Then remove the toner bottle be careful the hole might be on the bottom toner is going to go everywhere. Then close the front cover and turn on the machine. Let the machine go through it normal routine. When it asks for toner install the toner correctly. If THE KNUB on the side of the bottle is damage put a new one in that KNUB is what the toner motor uses to turn the bottle if it damage you get a code. If that does not work you might have a bad motor or the home sensor or actuator for the toner bottle is bad worse case the control board is bad
Konica Minolta Minolta Di450 Di470 Di550 Copier Mt Toner 502a 8936-902 Logo
Popular Tags
48 questions posted
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Konica Minolta Office Equipment & Supplies
Most Popular Question
error code c0045
  • Office Equipment & Supplies
