20 Most Recent
HP PSC 1205 InkJet Printer Questions & Answers
I can't find my printer
Please make sure that you have installed necessary drivers for your printer. If you have not installed any drivers, then you download the driver by visiting the link below and selecting your computer operating system.
HP PSC 1205 drivers
If this does not solve your issue, then please revert back.
I have a hppsc1205. how
Hello and Welcome to FixYa!
Its easy as 123, follow this;
- Goto your Control panel from PC.
- Double click Printers (& Faxes)
- Find your printer installed, i.e; PSC 1205 (There may be written 1200 series)
- Right click and click on Printing Preferences.
- A dialogue-box will open, click on the COLOR tab.
- There you will see the options, to Print in color, print in grey-scale or Black and White only.
You are done.
If you have any Confusion, questions or issues regarding your problem do tell me.
Thank you for using FixYa!, Keep visiting..
If you think I was of help, your token of appreciation in the form of rating and a testimonial will be esteemed.
Concerned, Nooh
Check print cartridge blinking cartridges refilled
If the message on the computer does not identify a particular cartridge (it says only Print cartridge error
), follow the steps below to determine which cartridge is causing the problem.
- Open the cartridge access door.
- Remove either cartridge (not both).
Close the cartridge access door.
If the computer message is Print Cartridge Error
, then the print cartridge that is still in the printer is the problem cartridge.
If the computer message is NOT Print Cartridge Error
(instead, it says that the cartridge you have removed is ...Either missing, not detected, or incorrectly installed), then the cartridge you have removed is the problem cartridge.
- If the problem still occurs, the electrical contact between the
cartridges and the printer might be bad. Removing and reseating the
cartridges might help. Also, you can clean the electric contacts on the cartridges with a dry cloth.
Hope that will help solve your problem!
Printer HP psc 1205 incompatible with Vista
Follow this
link and see the availability of drivers for your printer. Just type your printer model and search (Eg laserjet 1200 )
or copy and paste this link to your another window of the browser
http://www.hp.com/#Support
All the lights flash and cant be switched off
You can download the manual from HP's website
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=uk&lang=en&os=228&product=240975&
Also try the solutions here for the flashing lights...
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00095908&tmp_task=solveCategory&lc=en&dlc=en&cc=uk&lang=en&os=228&product=240975
