20 Most Recent
HP DeskJet 930c InkJet Printer Questions & Answers
Deskjet 930C won't print at all
Hi Mary,Try the steps belowGo to Start / Run and type in "services.msc" without quotation marks, then press Enter or click OK.(If you are using Windows Vista/Win 7, You need to click on START button and under search program and files - Enter the Services.msc and click the same program from Program list that appear )In the window that opens (Services) look for "Print Spooler" on the rightRight-click "Print Spooler" and select "Properties".Click on the "Recovery" tab and change all 3 drop-down boxes to "Restart The Service".Make sure the 2 text boxes underneath say "1" in them.Click Ok until you are back at the Services window, close it and you're good to go.Go back into the properties of the "Print Spooler" tab and be sure to click Start to restart the Print Spooler service and it will restart the service immediately.The Print spooler depends on the Remote Procedure Call (RPC) service. Is this service disabled? Go to services.msc look for RPC. Check state: AutomaticRegards,Sean
How can I make my HP 930c print with no color
you cannot make it print with no cart, but if you have an old one, drill holes in the top and fill with water, 930c uses weight to establish ink level, after much mucking around I have done this today, printing right now :)
Print in gobblegook
Your document is corrupt. try a different document to see if the problem still occurs. Good luck !
How can i connect parallel connection printer to computer with USB only
You need an adaptor for that printer.
SEE HERE
These can be purchased at quite a few places
Hope this gives you the information you need
Bob
EXMOD
It would be very decent of you to consider the quality of our experts answers and judge them accordingly as you pass through FixYa.
Thank you
ACQUIRED A MINT CONDITION 930C.
you need ink to test print an image. even the alignment test tool uses ink to align the print heads. so without ink you cannot print anything!
I cannot download the driver
How are you installing the drivers, is it from the website or from the Disc that came with the printer? You can download an update on windows that contains the drivers for the printer.
Here is the link. download and install it, then try to add the printer : look at the picture below:
You don't need to click on the windows update anymore.
Thank you for using Fixya.
How do I change from colour to black and white on
Hi and welcome barry_nel450 !
Under Windows 7:
Select the file you want to print and click on " print " . A window opens : click on " preferences " \
" features " " print in gray scale " . Click now on the arrow next to" high quality" and select
" black ink only " .
Under Windows XP :
"paper/qulity " and check " black and white " .
Don't forget to click on " apply " when done in both cases !
Best regards ,
Fanaudi .
Is there any way to
Under your printer preferences there is a way to print gray scale. SO even if your image is in color, it will print black and white. Every printer interface is different, but when you go to print, there's usually a properties or setting button that will bring you to another page from the initial print menu. here is where you would choose gray scale.
If you try for black with only a color cartridge, it'll come out a dark green or blue color. Or on some cases, it will tell you it's out of black and you can't print. Most HP printers need at both cartridges in the printer for it to print.
