20 Most Recent HP Designjet 4500ps InkJet Printer Questions & Answers
I am trying to install the hp 4500 g510 to my computer. The options that I am getting are hp 4500 g510 a-f class, are they the same?10
no there not quite the same some versions of this model have a document feed - some don't ,- the product Number is what you should use to find the correct driver which could be one of the following-CB867A/CB877A -CM743A/CM744A-if you look at the serial number Sticker(with barcode) it will have one of these id tags on it - use this code in HP website to locate the correct driver
1/27/2014 10:05:26 AM • HP Designjet... • Answered on Jan 27, 2014
0answers
0answers
Error 01.0:01
Be the first to answer 11/27/2013 9:15:08 AM • HP Designjet... • Posted on Nov 27, 2013Be the first to answer
0answers
8:11 error
Be the first to answer 10/26/2013 5:55:08 AM • HP Designjet... • Posted on Oct 26, 2013Be the first to answer
26.001 error hp 4000
26.0:01 is a bad contact in the Ink Supply System for the yellow ink cartridge. (This can be caused by using non HP OEM ink)Check that the ISS to Cartridge cable is not damaged and is fully connected to the Ink Supply Tubes PCA.You can also try switching the magenta contacts with the yellow contacts and see if the problem stays with the yellow, or you now have a magenta problem.If the problem stays with the yellow, then you will need to replace the Ink Supply Tubes and Trailing Cable.If the problem moves to the magenta, then you just need to repair or replace the contacts (may just need cleaned)Good luck ! (My money is on bad compatible or refilled yellow ink cartridges)
10/16/2013 7:30:16 AM • HP Designjet... • Answered on Oct 16, 2013
0answers
Yellow printhead #1 error
change line sensor, because when the move carrige unit red lighth ok, but blue light epsent
3/17/2013 2:38:52 PM • HP Designjet... • Answered on Mar 17, 2013
0answers
How can irid of the hp product assistant poping up
here is a link that can help you get rid of the pop-up problem
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00857352&cc=us&lc=en&dlc=en&product=1153494&dlc=en&lang=en
hope it helps.
3/6/2011 7:33:58 AM • HP Designjet... • Answered on Mar 06, 2011
2answers
Cannot free paper jammed in hp 4500 printer
you will need to be gentle because the paper will be blocking the sensors
10/21/2010 5:20:48 AM • HP Designjet... • Answered on Oct 21, 2010
What causes an error 24.10 on a designjet 4500ps
System Error: 24:10
Problem
Description:
Broken bag detected in Ink Cartridge.
Corrective Action: Try the following:
�� Remove the Ink Cartridges and check for ink leakage in the ISS area.
�� Perform the "Bag Broken Recovery" Diagnostic (→ Page 4-51) to further
troubleshoot the error code.
Download the service manual at: www.lpscomputer.com/ec/manuals.htm
4/16/2010 6:41:48 PM • HP Designjet... • Answered on Apr 16, 2010
Hi Hp designjet t520 printer when i print the reportthe cyan color change his place with magenta color and yellow is dark thanks i need to help
check the catridges thier must be a mixing up of color when you were refilling the catridges
3/15/2022 4:11:23 PM • HP DesignJet... • Answered on Mar 15, 2022
Error 79:04 HP 650T
79 errors are usually bad firmware that needs replaced or updated. Sometimes it is simply a bad print job being sent. Check to see if only one print job is causing this error, or if it happens with everything you try to print.
5/8/2020 3:49:18 PM • HP DesignJet... • Answered on May 08, 2020
HP Designjet T3500 Ethernet port not working
To solve issues visit https://support.hp.com/in-en/document/c04530811 to get quick support call our Toll-Free 1 888 224 4280
7/30/2018 5:24:16 AM • HP DesignJet... • Answered on Jul 30, 2018
HP Designjet 4500ps InkJet Printer Logo
Popular Tags
21 questions posted
k24674
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
DesignJet HP
  • DesignJet HP
Most Popular Question
causes error 24 10 designjet 4500ps
  • Office Equipment & Supplies
