20 Most Recent HP Designjet 110plus nr InkJet Printer Questions & Answers
What is the cold reset for 110plus
To set to factory defaults, Hold power button down and press the cancel button 3x and the resume button 2x.
9/20/2021 1:09:19 PM • HP Designjet... • Answered on Sep 20, 2021
3answers
How do I clean the HP designjet 110plus printhead
You need to go to the hp download site and download the System Maintenance Utility Software. Its free, but you need it before you can clean the print heads. also, for some reason it works best when hooked to the network, not directly to Computer.
7/30/2021 7:06:37 AM • HP Designjet... • Answered on Jul 30, 2021
HP Designjet 110plus nr not detect the roll paper
Fig 1.ptaf4hvjb1qk8cwuku4haaaaaelftksuqmccFig 2lrkaaaaasuvork5cyii=Fig 3x8bd0nstucf9psaaaaasuvork5cyii=Remove top cover (fig 1), observe the location of the paper sensor (fig 2) press both sides of the sensor to unlock & pull it up gently as shown in fig 3. Observe the sensor flag has to move both directions freely and it has to maintain home position with the help of two springs. In case of any one of the spring dislocated flag struck respective direction..I think one of the spring dislocated in your case.. observe & fix it proper.. best of luck...
2/11/2021 9:51:02 PM • HP Designjet... • Answered on Feb 11, 2021
0answers
HOE TO CLEAN PRINTER HEADS
its depending on the brand, and if you have cartridges with or without integrated printheads, with integrated printheads its much easyer and it spills less ink, but the cleaning you can mean not the clean function on the printer self but to clean with a cartridge flush , i have done it several times with a coffee saucer with some lukewarm tap water, years ago by canon printers perfect but there is the loose printhead but there is a special flush-alcohol for if its clogged but after that if you print not much you can then best printhead thus it maintained flush him briefly just after the changing of cartridges and especially if you himself refilled it keeps closing rubbers clean where the cartridges are placed so that it stays clean , but as soon if a printhead is for a more then short time glogged if it is dry the printhead fails due to lack of cooling most times the refill can comes too late. but if only neccesary to clean when clogged nozzles use always a good special cartridge flush
2/12/2016 1:36:44 PM • HP Designjet... • Answered on Feb 12, 2016
Only the black ink is printing blurred?
Remove the black cartridge and gently clean the jets.
2/12/2015 10:08:40 PM • HP Designjet... • Answered on Feb 12, 2015
I didn't use my printer
In many cases after a printer has not been used for a long period of time, the ink will become dry. Most printers will have a "Clean print heads" option. Also trying to print a page or two may resolve the issue. If it continues however, the printer may need replaced. Dried ink can block the print heads and in some cases can not be unblocked without taking the printer apart, which will void the warranty.
11/17/2014 8:53:06 PM • HP Designjet... • Answered on Nov 17, 2014
0answers
Paper cutter not working
chenge the Paper cutter
4/19/2014 6:22:05 AM • HP Designjet... • Answered on Apr 19, 2014
No power to hp design jet 110
check the internal power supply board connection cable
4/19/2014 6:20:03 AM • HP Designjet... • Answered on Apr 19, 2014
2answers
My designjet 110 turns on
Could be a problem with the print heads, try new printheads from HP.
4/19/2014 6:07:51 AM • HP Designjet... • Answered on Apr 19, 2014
0answers
Will not print put new ink in it was not used for 2 years
You need to clean the print heads. Use qtips and rubbing alcohol. It will take some soaking and multiple cleanings
3/16/2014 3:18:14 AM • HP Designjet... • Answered on Mar 16, 2014
Black ink started to print blue/mauve
Many thanks for the suggestions received. Have been told by HP to
change the black printhead - which has solved the problem!
11/5/2013 5:11:48 AM • HP Designjet... • Answered on Nov 05, 2013
What is a default format?
You're posting in the wrong section... This is Air Conditioning section---
11/5/2013 3:14:42 AM • HP Designjet... • Answered on Nov 05, 2013
HP Designjet 110plus nr InkJet Printer Logo
127 questions posted
k24674
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
DesignJet HP
  • DesignJet HP
Most Popular Question
am trying print large picture
  • Office Equipment & Supplies
