20 Most Recent
Casio Exilim EX-Z120 Digital Camera Questions & Answers
How to remove date and time stamp
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Обычная таблица";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
mso-para-margin:0cm;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
There is a special tool
that can easily remove date stamps, watermarks and other unwanted objects from
your digital photos:
http://www.softorbits.com/photo-stamp-remover/
My Casio ExilimEX-Z120 shows 'Low
It happens because some alkaline batteries just don't have the initial surge of power output required to drive all the little motors, the display and so on.
You need lithium batteries, like the 8x Ultimate Lithium.
They are expensive initially, but on average are more economical than the cheaper stuff.
I've tested them on my Kodak Z712 IS, and any owner of this camera knows what I'm talking about.
The best -and cheapest- solution I found, is the rechargeable Li-Ion batteries.
I got 2 batteries and one charger. I'm using one battery, while the other one is charging.
Do you have a website where i can download the
You don't need any special software.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as
Picasa.
Casio ex-z120
It doesn't matter to the camera what software you have on your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as
Picasa.
Sdhc not recognized
The EX-Z120 works with MMC and SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work with this camera. You need to use SD cards, 2GB and smaller.
Cannot take a picture--message: "your card is
Take the memory card out of your camera and look at it. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
