20 Most Recent
Sony Cyber-Shot DSC-T5 Digital Camera Questions & Answers
Camera doesn't recognize lens cover...
I rednecked the crap out of mine. I pulled off the slide cover and placed a small piece of paper clip in the area of the copper to make a permanent contact. Then duct taped it secure and then cover the whole slide mechanism. I would not recommend this method but it worked.
Reinsert memory stick
Remove the memory stick, get a USB reader that will support that stick...then pull pictures off. Once that's completed, look at the memory stick's contacts, do they seem "dirty"? May need to use a soft pink eraser to get the oxidation off. Also, try compressed air in the camera to blow out any dust that is in there...don't use your compressor, pick up a can from Staples or something.
Pictures deleted from memory stick duo
If you have access to a computer then download PCInspector for www.convar.com
This will recover lost images on media card so long as they not been overwritten.
How this works out with a PSP I would not know.
How can I change the
Press the MENU button to bring up the main menu. Select the toolbox icon, then select the toolbox-1 icon. Select the "A" icon, then select the desired language.
You can download the English-language manual and more from the manufacturer's web site at
http://esupport.sony.com/US/perl/model-documents.pl?mdl=DSCT5
The charger of Dsc-t5 is blinking
The supplied charger normally lights while charging and turn off when the battery is fully charged. If the battery charger is blinking, then issue may be with the battery not getting charged. I suggest that you try using a different battery and check if the issue is with the battery.
Thanks for using FixYa.
I can't transfer my pictures
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
I was given a Sony
There should be a button with an icon of a lightning bolt. Press that button and watch the screen...when you see a lightning bolt with a diagonal line through it, your flash is off.
My friend accidentally dropped my
Apparently no physical damage but camera result shows internal damage of lens mechanism and lens assembly need to be replaced by local camera repair shop because camera will take apart for that and lens assembly can not be repaired, replacement is only option.
Let me know if there is additional question.
Thanks.
How you can eliminate the
Hello and Welcome
The symptoms of this error is
After pressing the power button in capture mode, the lens would extend and a slight humming from what appeared to be the auto focus motor could be heard for about 5 seconds. When the motor stopped humming, the camera would beep and display E:61:00 in the LCD Screen.
- Camera would extend the lens but not be able to focus on anything past 8 inches or so.
- Zoom in and zoom out would not work.
- Playback mode and the Setup mode was not affected.
To solve this
Put the camera about a half inch from a hard surface.
Let the lense go out and hit the surface and retract a little bit. Let it go out all the way when it tries the next time.
If that doesnt fix it, try this:
Turn it on and let the lense go out fully
See where the lens comes out of the camera? The little round crack that surrounds it? Wiggle the lense a bit and blow in there a bit. (Be sure not to blow on the lense!)
Now turn it off/on again, and it should be fixed
See the following video, It may also help you
Your Rating As Four Thumbs which are given below to this solution will appreciate me
Thanks and Keep using Fixya
I am getting a E:61:00 error on my Sony T5.
amitchhab276:
From the user manual for your DSC-T5 (click here), that error message means:
E:61:xx
E:91:xx
A camera malfunction has occurred. Initialize the camera (page 52), then turn the power on again.
From page 52: After you have cycled-power, you need to go to the Setup1 screen and select "Initialize" and choose "OK" with the up arrow and then press the circle button. Again press the up arrow and circle to select "OK" to reset the camera to default. settings.
Make sure that the power is not disconnected during reset!
