20 Most Recent
Dell UltraSharp 1504FP Monitor Questions & Answers
Monitor went black and now stays black after
pdshapiro, Learn flashlight test in my fixya profile to determine current state of shutdown of units "switch-mode-power-supply"... Then do more reading and visit some of the web links mentioned in my many responses to other owners of Black or Blank n Black screen monitors. You will find out all you need to know and all options if you read my older (late 09 posts) responses to other owners of same or similar sympton ccfl back-lit lcd monitors. JUST DO SOME READING FIRST. Then come back to this post and give it a rating if it steered you in the right direction. Bye for now. 12fixlouie
Dell FP1504 Displaying very dark " Ithink this is backlight issue
If you are not a technician you can´t solve this problem because are to desasembly your device and check the Q7 and Q8 and C5 that components are on bad conditions and need to be replaced,I told you because i repaired one of these monitors for the same problem
I can not find the correct drivers to configure my
Are you sure that your problem is with the monitor drivers? Usually when graphics card drivers are correctly installed, the monitor is recognized as "Plug and Play monitor" and this is completely sufficient, as the monitor is able to communicate it's supported resolutions and refresh frequencies to the video card.
Look for an updated graphics driver for your system - first you have to establish what type of graphics card you have, then find drivers for it.
Dell UltraSharp 1504FP Monitor - Blank Screen
well friend if the fuse is the problem, you will not see any power light indicator. probably theres a problem in power supply circuits or most probably the horizontal deflection circuits. which includes the horizontal oscillator, horizontal drive, horizontal output and maybe the flyback itself. but if you dont know anything about this, better bring it to a qualified tv technician. good luck!
MODEL DELL 1504 FP
I have one with no backlight. The capacitors on the board are bulging. In my opinion they were designed too close to tolerance and "cooked out". As long as it's still working change the ones in the Regulator circuit(3 in the middle of the heatsink area), and the four really small ones over by the transformers. Should be right as rain.
