20 Most Recent
Sony Handycam DCR-PC2E Camcorder Questions & Answers
How do i connect my sony dcr pc2e to a computer to download video
This is probably going to be a camera driver issue. Look for the updated drivers for that camera to your operating system. Make sure also to have the correct firewire driver which is usually on the sound card. Check soundcard drivers as well if your port is on it.
Sony DCR-DVD200 camcorder not turning on after trying to fix it.
The best thing you can do now is to take it to a specialist and get them to do the repairs. Camcorders have a lot of electronics in them and can be easily damaged if your a not an experienced repairer. You might also have to consider that this camcorder might not be repairable.
Blue screen on TRV260 playback
TRV260 nail-polish head attack:
eek.
Acetone is a powerful solvent capable of dissolving plastic parts, plastic gears, housing and insulation.
Besides that, it leaves a residue of microscopic crystals which have probably contaminated the highly-polished metal head drum.
Not to mention gumming up the bushes and bearings.
With your next camera, rather use a head-cleaner DV-tape.
Sony dcr-hc62 won't record
Memory stick could be fubar. I have a bad sd card that I can record to and will work. Then a few days later the data is corrupted, and I have to reinstall it / same pattern. Try another stick to verify that it is the stick and not the camera electronics.
