20 Most Recent
Sony Handycam DCR-VX700 Camcorder Questions & Answers
Hello i dont know how to import the videos in the
you need some specific software to get or do anything with the video. even if the camera did not come with the software check for downloads available from sony first. then in addition there are also be many other options, some certainly free, depending on your platform (mac, ms, linux, etc.) a little web searching should find several options for you..
Sony DCR-DVD200 camcorder not turning on after trying to fix it.
The best thing you can do now is to take it to a specialist and get them to do the repairs. Camcorders have a lot of electronics in them and can be easily damaged if your a not an experienced repairer. You might also have to consider that this camcorder might not be repairable.
Blue screen on TRV260 playback
TRV260 nail-polish head attack:
eek.
Acetone is a powerful solvent capable of dissolving plastic parts, plastic gears, housing and insulation.
Besides that, it leaves a residue of microscopic crystals which have probably contaminated the highly-polished metal head drum.
Not to mention gumming up the bushes and bearings.
With your next camera, rather use a head-cleaner DV-tape.
Sony dcr-hc62 won't record
Memory stick could be fubar. I have a bad sd card that I can record to and will work. Then a few days later the data is corrupted, and I have to reinstall it / same pattern. Try another stick to verify that it is the stick and not the camera electronics.
