20 Most Recent
Zodiac Mens ZMX 03 watch ZO8506 Questions & Answers
ZO1002 zodiac watch battery replacement and any info and instructions would be amazing impossible to find online
Opening the Watch Back If your watch back has no screws and only pin holes, it might be a snap-off case back. Here are some general steps to open a snap-off watch back:
Use a thin blade or a similar tool to pry the back off. Be careful not to scratch the watch.
Insert the blade into the seam between the watch back and the watch case.
Apply a small amount of pressure to lift the back off.
Please note that these are general instructions and may not apply exactly to your specific model. If you're not comfortable doing this yourself, I recommend taking it to a professional.
Adjusting the Links If you need to adjust the size of the watch band by removing or adding links, here are some general steps45:
Look for the arrows on the underside of the band. These arrows indicate the direction to push the pins out.
Use a pin pusher or a similar tool to push the pin in the direction of the arrow.
Once the pin is out, you can remove the link.
To reattach the links, insert the pins in the opposite direction of the arrows.
A jeweler or watchmaker might open this for you otherwise.
I found some general instructions for operating quartz watches which might be helpful but I can't find specifics for your watch. You can try contacting the manufacturer, otherwise.
To set the time, pull the crown out to the second position. Turn the crown to adjust the hour and minute hands. When the day changes, the watch moves to AM (ante meridiem) status. The day will change automatically during the period between midnight (0:00) and about 5:30 am.
After setting the time, push the crown back in to the first position. The watch and the seconds hand will restart, now set to the exact time
