20 Most Recent Sony Handycam HDR-HC1E HDV Digital Camcorder Questions & Answers
My Sony HDR-HC1 NTSC will not power on.
What if there's no tape inside of the camera, does it still same?
2/9/2018 5:42:44 PM • Sony Handycam... • Answered on Feb 09, 2018
0answers
0answers
Camera LCD screen
Perform the following troubleshooting steps and check whether it helps;
1. Check whether the issue persists with all the tapes. If the issue persists with a particular tape, the issue is with the tape. change the tape. 2. Check whether the battery is fully charged, 3. If the batteruy is nit fully charged, connect the Camcorder to the wall outlet using the supplied AC adaptor. 4. Then, reset the Camcorder by pressing the RESET button using a sharp-pojnted object while it is turned ON.
5. If the issue still persists, remove the battery pacjk and disconnect the Camcoredr from the wall outlet; then slide the power switch to ON position for at least 30 seconds. Then reconnect the AC adaptor to the Camcorer after 1 minute.
If the issue still persists, service may be requuired. Please cointact ur Camcorder manufacturer to get it serviced.
6/27/2011 12:41:17 AM • Sony Handycam... • Answered on Jun 27, 2011
Loading tape
Tape mechanism problems can be quite complicated but they can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be diagnosed by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
12/25/2010 9:01:32 PM • Sony Handycam... • Answered on Dec 25, 2010
I have a Sony HDV Handycam about 4 years old and
me too - any solutions?
7/6/2010 2:23:54 AM • Sony Handycam... • Answered on Jul 06, 2010
Hi I have DRC-SR200 camcoder, bought one year ago.
Hi, perform the following steps to get this issue resolvbed... 1. Check whether the lens cover is opened 2. check whether the battery is fully charged. If the battery is not fullly charged, connect the Camcorder to the wall outlet using the sipplied AC adaptor. 3. Then, try resetting the Camcorder by pressing the RESET button using a sharp-pointed object while the Camcorder is turned ON. 4. If the issue still persists, turn OFF the Camcorder; then remove the battery pack and discinnect the Ac adaptor from the Camcorder; slide the POWER switch to the ON position for 1 minute. Then, connect the AC Adaptor tro the wall outlet and cjeck whether it helps.
If the issue still persists, service of the unit may require. contact the manufacturer of the Camcorder to get ut serviced.
1/15/2010 5:49:45 PM • Sony Handycam... • Answered on Jan 15, 2010
HELP ME PLEASE
If moisture condensation has occurred, remove the recordable media (tape) and then turn off and leave the media compartment open for the hour the camcorder is turned off . The camcorder can be used again if the warning indicator does not appear when the power is turned on again.
Moisture condensation normally occurs when the camcorder is brought directly from a cold place to a warm place. It can condense inside the camcorder, on the recording media, or the lens and cause a malfunction.
To prevent moisture condensation when you bring your camcorder from a cold place into a warm place, put your camcorder in a plastic bag and seal it tightly. Remove the bag when the air temperature inside the plastic bag has reached the surrounding temperature.
1/15/2010 5:43:31 PM • Sony Handycam... • Answered on Jan 15, 2010
2answers
Hi, during a repear of my
Hi
Plastic tabs, and small connectors / connector holders don't make a good business.
I've never seen anyone who would sell those mainboard parts. You will most likely have to contact the manufacturer of the mainboard and see if you can get them to sell you the part, or ask another expert, maybe someone on this site knows. But I'll bet this is the best you can get.
12/19/2009 12:42:00 AM • Sony Handycam... • Answered on Dec 19, 2009
2answers
Sony camcorder has knocking noise in recording or playback
Try using tapes of different sizes. a big tape may be exerting stress on the mechanism
9/18/2009 6:44:01 PM • Sony Handycam... • Answered on Sep 18, 2009
The lcd screen is almost black/ very dark, but i
The LCD screen may be turned OFF. To turn the LCD backlight off or on, press and hold the DISPLAY/BATT INFO button for a few seconds. After the backlight has turned off or on, release the button.
8/8/2009 11:05:02 AM • Sony Handycam... • Answered on Aug 08, 2009
My Sony HDR HC1 will not power on.
this is some problem with the internal software or hardware. nohting to do with externals. check it out by doing a hard reset.
3/9/2009 2:32:14 PM • Sony Handycam... • Answered on Mar 09, 2009
Lens Cover not fully open
It sounds like a problem with the firmware in the camcorder itself. As an authorized Sony repair person, I have gotten no technical bulletin on this model. The firmware is preloaded into the microprocessor IC. You will need to have this unit looked at by an authorized Sony repair center who specializes in camcorder repairs or send the unit to a Sony factory service center. good Luck
6/6/2007 11:16:22 AM • Sony Handycam... • Answered on Jun 06, 2007
CAN I SAVE MY HD TAPES TO DISC AND PLAY BACK AS HIGH DEFINITION?
At this point, unless you have a blu-ray or HD-DVD burner in your computer (and equivalent player), then you can't save HD to a DVD and have it play back in a regular DVD player. You should be able to transfer the HD video through firewire to the computer, but you might have to wait for a while until you can burn them to HD compatible DVDs. The only other option that I know of is to encode the HD video using a DivX codec (http://www.divx.com/) and just burn the file itself to the DVD, then if your DVD player can play DivX files, then you should be able to play it back on that.
5/27/2007 3:34:57 PM • Sony Handycam... • Answered on May 27, 2007
Sony DCRA-C162 Camcorder. I need a replacement battery for the DCRA-C162. Does anyone know where I can get one?
Question edited for clarity, add full 'make model (what it is)'. Question moved from Cars and Trucks category. Searching for your manual keeps bringing up this manual https://www.sony.com/electronics/support/res/manuals/2698/26988801M.pdf Looking at that manual Page 16, it states the battery pack as 'NP-FP50', and that turns up batteries for $15. https://www.google.com/search?q=NP-FP50 ..
11/20/2023 12:02:19 AM • Sony Handycam... • Answered on Nov 20, 2023
Sony Handycam CCD-TRV68 Flashing No Tape and Eject Symbol
If it were worth repairing, as a Sony agent, I would replace all of the capacitors and clean up the board then reset the mechanism and test. Probably too old being 2001 vintage.
11/19/2023 12:20:58 AM • Sony Handycam... • Answered on Nov 19, 2023
SONY mini HandyCam model V569. HOW DO YOU TURN ON A SONY V569?
Question edited to add full model designation. Question moved from Sony Computers. This doesn't seem to be a very well known model. It is not even listed on their website. https://www.sony.ca/en/electronics/support/cameras-camcorders/manuals/results?query=V569# There are normally two batteries, a small one that just saves memory and runs the operating system, and a larger battery that actually powers the camera. Try contacting Sony direct There is a bit of help here, but not enough. https://www.google.com/search?q=SONY+V569 ..
8/4/2023 4:37:50 AM • Sony Handycam... • Answered on Aug 04, 2023
Sony Handycam HDR-HC1E HDV Digital Camcorder Logo
23 questions posted
Top Sony Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
View Most Popular
Handycam Sony
  • Handycam Sony
Most Popular Question
sony hdv handycam about 4 years old
  • Video Cameras
