20 Most Recent
Creative Labs I-Trigue L3800 Computer Speakers Questions & Answers
My Creative I-Trigue L3800 speakers have stopped
don't know but i'm in the same boat. the white connector on the subwoofer does not receive sound. either the left or the right speaker will work when plugged into the red female connectors but neither works with the right. fuse is all i can think of. know where to get one?
I have Creative I-Trigue L3800 Speaker System, but
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
if you dont have a disk with the drivers you will have to download themhope it helps
NO sound from the speakers
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
don
No Sound from External Speakers....only from Headset plug.
Hi, had same problem.... unscrew the remote and carefully remove the back end part of the stereo-connector (very careful !) it consists of a very small switch which moves sideways..... this switch is stuck into headphone-modus. Reassemble and it will work again
Note that speakers will work if you remove the switch
Hi, Is there a plug that will allow bulk printing
You can use this ONLINE tool from eBAY. ITS COMPLETELY FREESelling Manager is an online tool designed for medium-volume sellers to help
manage and track listings on eBay. Selling Manager is conveniently located in My
eBay. Use with Turbo Lister for a complete solution.
• Monitor active listings
• Generate bulk feedback and print invoices
• Print invoices and labels in bulk
Bulk Printing (Selling Manager Pro)
Selling Manager Pro subscribers can print as many as 200 invoices or shipping
labels at one time from the Sold View.
To print multiple invoices and shipping labels:
In the Sold View, check the box next to the listings that you want to print
invoices or shipping labels for and click the Print button.
To select all of your Sold items, check the box in the heading bar above
the list of sold items
From the Print page, select the printout you want, and click the Continue button.
In the pop-up window that appears, use the scroll bar to preview each of the
pages that will be printed.
Once you are satisfied with how the pages will look, click the Print button in the browser window.
If you need to edit information for a specific page, go the corresponding
sales record. When you are finished updating the sales record, save your
changes. Your changes will be reflected the next time you print.
This pro version is available for approx $5 per month
My IC BT9843 is burnt I need an equivalent to replace it.any help please?
Try searching again using Google, using BT 9843, but when you look down the results ignore the two letters and see if you can find an IC which is the same numbers, even if it has different letters on the front. Those letters could be just the makers letters, with the device made by different makers.
Barely see screen
If the brightness is all the way down, simply turn it up.
If not this indicates an issue with the device and you should take it to your local tech repair shop
