20 Most Recent
Brother DCP-J125 Questions & Answers
How to clear unable to print49
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, and then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart, hopefully without the annoying cannot clean message.
Some times this happens because of using cheap compatible ink cartridges if this is the case change the ink cartridges.
I have not used my brother DCP-J125 for sublimation for a few months and it does not print now? What can I do?
clean several times your machine by pressing menu ink management clean and all .connect to electricity and open machine long press menu key while opening machine long press menu key until it shows maintenance in black background then press up key near OK bottom it increase number and down key decrease number press up key until there is number 8 then press OK again 0 OK press mono key until it shows Purge after it shows purge then press 2 OK 7 OK 8 OK 3 OK it shows purge 00000 then press stop Key then press 9 OK 9 OK your machine will start automatically. and your machine is ready to use again.
Unable to lnit.af
The flat cable of the scanner might not be connected properly, check it if you have taken it off earlier.
