20 Most Recent Bosch HBL 5052 Electric Double Oven Questions & Answers
Bosch fan oven HM48141 "GRILLING PROBLEM"
Understood Wbrowne08, Being from California... I have the same issue trying to grill my chili con carne y frijoles (especialmente)... For oven grate issues... I generally wrinkle up some aluminum foil and then gently spread it over the grate... (I am pretty lazy & don't care for the clean-up... (or a serous BEATING from my wife... (just kidding))). But... a NEW product... COPPER GRILL SHEET could be exactly what is needed to fill that VOID in your oven "grilling": Copper Grill Bake Mat As Seen on TV Also seen on eBay and AMAZON... Amazon com Atiyoc Copper Grill Mat Set of 4 Non stick and Heat Resistant... As to the BOSCH design... and the value of your money... Hey (you bought it (what's that about))... We are not affiliated w/BOSCH... No way, no how. Be healthy... Cook HEALTHY... Carnac the Magnificent
12/2/2017 3:26:26 PM • Bosch HBL 5052... • Answered on Dec 02, 2017
0answers
After a power outage, how do you unlock the doors
Reset the time. Here is a user manual, this link will download the manual right to your computer, in PDF form.
9/24/2011 12:08:20 AM • Bosch HBL 5052... • Answered on Sep 24, 2011
0answers
Oven wont heat up, the
Thanks for choosing FixYa and welcome. If you have a electric oven or a gas oven that won't heat or doesn't heat properly, here are some things you will need to check. The most likely cause of a oven not heating correctly is a defetive heating element. You have two types of heating elements in your oven. The bottom element(s) are the baking elements. The element(s) on the top are the broil elements. If you don't see the bright red glow from the element, chances are they are not working or not working correctly. If a heating element is bad, you need to replace the entire element. If your oven is warm and not correctly hot, one of the elements may be bad. In most ovens, when you preheat, both elements are used. This would make the oven to appear like it is working correctly but it is not. If the elements are not working, they might not be getting power. Test the wires to the elements with a voltage meter to make sure they are getting power before you decide to change them out. Many electrical ovens have a sensor that monitors the oven temperture. Ovens that have this sensor usually contain a digital display on the oven. The sensor could be defective. Those without the sensor use the basic mechanical system to control the oven temperature. You also want to check the thermostat sensing bulb. Make sure the bulb is good and has not come loose. Now, if you have a gas range oven that doesn't heat properly, first, you want to check your bake igniter. It may have burned out or it could be not working properly. It will be located near your burner. It is also possible that you are not getting gas to the burner. If so, it may be the gas safety valve or the igniter. You need to check your selector switch and thermostat as well. They may be defective. Always make sure you test the parts for power with a voltage meter of some type before you decide to change the part. If you have a part that appears to not be working, it may not be getting power because of a bad wire or broken connection. Thank you for your time and thanks for choosing FixYa.
5/10/2011 4:22:34 PM • Bosch HBL 5052... • Answered on May 10, 2011
We have a neff double oven and the bottom oven
If the fan is working o/k, then it it is likely to be the oven element that has failed.
This is located at the rear of the oven compartment behind a removeable cover.
Please rate my solution.
Thankyou.
1/30/2010 3:00:41 PM • Bosch HBL 5052... • Answered on Jan 30, 2010
tip
Common heating faults with Bosch HBL 5052 double oven
For all Free appliance repair videos visit our VIDEO TUTORIALS 1, If the Bosch fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the BOSCH element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your BOSCH fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your BOSCH oven thermostat
4, A quite common and easily overlooked answer is if your BOSCH oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
tip
Bosch HBN13M250B/01 not heating or fan is not turning, common faults.
For all Free Bosch appliance repair videos visit our VIDEOTUTORIALS
A fan oven that has stopped heating up is probably the mostcommon oven fault that professional engineer is called to. The cause inmost cases is simply a faulty fan oven element. To employ the services of arepair company is going to cost you in the region of £60 - £100 to complete thejob.
With a little time, though and our FREE fan oven element video itshould take less than half an hour to repair, and the element can be purchasedfrom us for as little as £20 ! Why not Save yourself some money and read on
1, If the Bosch fan motor in the back of the oven isgoing round and the temperature light is on (normally little red light), butthere is no heat then you will probably need a new oven element, these aregenerally very easy to fit and readily available from our website these can betested with a electric meter.
To gain access to the Bosch element you will haveto remove the back plate from inside the oven. Once removed you will see the Boschfan and element, if you look closely at theBosch element you will probablysee a small hole burnt in it where it has blown. Sometimes however there is noevidence of a fault but the element is open circuit ie: brokeninside the element casing, either way it will need replacing. Some elementswill are fixed from inside the oven and some are held in place by nuts from therear of the machine.
2, If your Bosch fan oven is getting warm but takes a very long time tocook or is burning the food more on one side than the other, then you need tocheck if your oven fan motor is workingyou will see the blade turning fast if it is ok. if the element is heating butthe fan motor is notblowing the heat into the oven then you need To replace the oven fan motor is alittle more expensive and a bit more involved.
3. If you have the opposite problem ie: your ovenis over heating and burning everything then you will need to replace your Bosch oven thermostat
4, A quite common and easily overlooked answer isif your oven is not working atall ie: no heat and no fan then the chances are that someone has put the oven timer into AUTOmode, simply put oven back to MANUAL mode and all should be working again.
Oven door does'nt close fully
Heavy doors wear out the rollers on the hinge and the hinge itself. Need to replace them in a pair but the are expensive.
4/25/2008 8:01:19 PM • Bosch HBL 5052... • Answered on Apr 25, 2008
4answers
Hi I have a bosch
Exactly what is going on with the oven? Maybe I can be of some assistance.
3/6/2024 11:10:16 AM • Bosch Ovens • Answered on Mar 06, 2024
I have a integrated Bosch oven and it bleeps when I open the oven door and when it has been on for over 30 mins. What does the beep mean?
Generally it tells you that the food is cooked if the 'integrated oven has a microwave function. Or of course it is a fault. You can often fix that with a Power Reset. https://www.google.com/search?q=integrated+Bosch+oven+and+it+bleeps+when+I+open+the+oven+door+and+when+it+has+been+on+for+over+30+mins ..
4/9/2023 7:54:55 PM • Bosch Ovens • Answered on Apr 09, 2023
2answers
Bosch single wall ovens where is the thermal fuse located
Hi! The location of the thermal fuse in a Bosch single wall oven may vary depending on the model, but it is typically located on the back of the oven. To locate the thermal fuse, follow these steps:
  1. Turn off power to the oven: Before attempting any repairs, turn off the power to the oven by unplugging it or turning off the circuit breaker that supplies power to the oven.
  2. Remove the back panel: Locate the screws or bolts that hold the back panel of the oven in place and remove them using a screwdriver or socket wrench. Carefully remove the back panel to access the components inside the oven.
  3. Locate the thermal fuse: Look for a small, rectangular device with two wires attached to it. This is the thermal fuse. It may be located near the top or bottom of the back of the oven, depending on the model.
  4. Check the thermal fuse for continuity: Use a multimeter to check the continuity of the thermal fuse. Set the multimeter to the ohms setting and touch the probes to the two terminals of the thermal fuse. If the multimeter shows no continuity, the thermal fuse has blown and needs to be replaced.
  5. Replace the thermal fuse: If the thermal fuse has blown, replace it with a new one of the same rating. Install the new fuse in the same location as the old one and reattach the back panel of the oven.
  6. Test the oven: After replacing the thermal fuse and reassembling the oven, turn on power to the oven and test it to ensure that it is working properly.
If you are not comfortable working with electrical components or if you are unable to locate the thermal fuse in your Bosch single wall oven, it's recommended to seek the assistance of a qualified technician. Kind regards
3/25/2023 5:49:23 AM • Bosch Ovens • Answered on Mar 25, 2023
My Bosch oven display flickers often. Other times the clock is displayed as usual. What does this mean?
first thing I would do is check the cables that go to the clock, if they are OK then you likely have a faulty clock module which will need to be replaced.
2/23/2023 12:55:56 AM • Bosch Ovens • Answered on Feb 23, 2023
2answers
The knob on my electric Bosch oven doesn't grip onto the shaft and keeps turning/ twisting round. the actual knob is ok and pulls off to check, but the problem seems to be with the white plastic shaft
Get some epoxy putty, grease the shaft with Vaseline, put a small pea size piece of epoxy rolled thinly and insert it into the knob where the flat part registers on the knob. Push the knob into place and leave it 24 hours to cure. I use this.
Epoxy Putty - Amazon.ca
https://www.amazon.ca > Epoxy-Putty > k=Epoxy+Putty Results 1 - 48 of 696 - Epoxy Putty Stick, Yanyi Moldable Epoxy Glue for Crack Damage Fixing Filling or Sealing. Fast Permanent Repair for Metal, Glass, Wood, ... ..
2/9/2023 6:51:00 AM • Bosch Ovens • Answered on Feb 09, 2023
Replacing Thermostat in Bosch HBL455AUC
Yes, the tube is fed in from behind or above. Some thermostat bodies have a small adjusting screw to allow you to calibrate if it is fairly close. The videos show it is a simple job.
1/23/2023 12:11:58 AM • Bosch Ovens • Answered on Jan 23, 2023
Bosch convection microwave HMC87151UC does not heat in convection mode.
The issue you're experiencing with your Bosch convection microwave not heating in convection mode could be caused by a few different things. Here are a few things to check:
  1. Check the settings: Make sure that the microwave is set to convection mode and that the temperature and time settings are correct.
  2. Check the element: The bottom heating element is responsible for providing heat during convection mode. Make sure that the element is not damaged or burnt out. You can visually inspect it, if it is damaged it will need to be replaced.
  3. Check the fan: The fan is responsible for circulating hot air during convection mode. Make sure that the fan is not blocked or damaged. If it is, it will need to be replaced.
  4. Check the control board: The control board is responsible for controlling the functions of the microwave. A malfunctioning control board could prevent the microwave from heating in convection mode.
  5. Check for a blown thermal fuse: A thermal fuse is a safety device that cuts off power to the oven if it overheats. If the thermal fuse is blown, it will need to be replaced.
  6. Check for a blown thermal cut-off: A thermal cut-off is a device that cuts off power to the oven if it overheats. If the thermal cut-off is blown, it will need to be replaced.
1/14/2023 11:05:03 PM • Bosch Ovens • Answered on Jan 14, 2023
Calibrating Bosch HBL 455 A UC Dual Oven
You may need to replace the thermocouple inside of the oven.
1/9/2023 5:59:45 PM • Bosch Ovens • Answered on Jan 09, 2023
Bosch wae24166gb/06 washing machine location heating element
The heating element is located on the back of the Bosch WAE24166GB/06 washing machine.
12/14/2022 10:45:12 AM • Bosch Ovens • Answered on Dec 14, 2022
Bosch HBL 5052 Electric Double Oven Logo
15 questions posted
Top Bosch Ovens Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a Bosch Oven Expert? Answer questions, earn points and help others
View Most Popular
Bosch Ovens
  • Bosch Ovens
Most Popular Question
oven wont heat up
  • Ovens
