20 Most Recent
Bosch HMB402 Microwave Oven Questions & Answers
When I put a bag of popcorn in the microwave, it
The first thing I would do is thoroughly clean the inside. Take particular care when cleaning around the upper left side. Sometimes a buildup of food steam or spray can cause the problem you are having. Never spray anything into the microwave, in an attempt to clean it.
Hope this helps.
I have a Bosch HMB405
If it is the magnetron you should be covered in warranty by Bosch.more likely problem is bad capacitor and diode ~ $45-50 parts $80 labor +service charge where applicable.Hope this helps. Please rate my response :)
Bosch range front glass smashed
open the oven door and look on the sides where the door meets the oven. also slide open bottom drawer and look where drawer meets oven. hope this helps!
My GE Profile Microwave/Convection Oven model
This
is usually caused by either a bad door switch, a loose door switch
mount (which are pretty simple problems to fix) or
occasionally a
problem on the control panel.
Even though a door
switch clicks, it may still be bad inside.
Door switch
or mount trouble is usually caused by slamming the door or by opening
the
door while it's cooking without hitting the Stop pad first.
There are
plastic mounts inside the microwave which hold the door switches and
onto which the door latches lock when you close the door.
The screws on these
mounts may be loose. If they get too loose, the switches will not be
activated properly.
Sometimes it's
a broken tab on the switch holder, allowing the switch to rotate just
out of position. This tab
can be hard to see, since it is under the
bottom edge of the switch.
If the switch mount is broken, it's usually more economical and
safer to add a dab or two of hot glue to the mount to secure the
switch. Let it cool for about 30 minutes before using.
You can find helpful
exploded view diagrams and order parts by entering your full model
number here.
There should also be a "mini-manual" hidden inside the unit behind the control
panel or hidden on the left side behind the grille, which is very
helpful when troubleshooting & testing.
At
our Web site, we have a video
available showing how to remove a typical
over the range control panel assembly in under 5 minutes.If you only need a
switch, you can order a universal type here for $5 postpaid.
If you think the problem
is on the control panel, we repair these nationwide by mail
for $39.95 postpaid in most cases in about a week or so.
Feel free to contact me directly (and please remind me of your
full model number from the tag on the unit) for more information & help.
We're
happy to help you with free advice and we'd appreciate your thoughtful
rating of our answer.
Setting clock on Amana Microwave Mod#FBG623T
It may possibly be locked, in which case holding the enter/start pad for over 3 seconds may unlock it.
Otherwise, you may want to call Maytag / Amana at:
1-800-688-9900 U.S.A
1-800-688-2002 Canada
Mind of its own!
there i s obviously a fault with the programming hold down your clear or reset button for about 20-30 seconds it should reset .or unplug at night.
