20 Most Recent Maytag LAT3600A Top Load Washer Questions & Answers
LAT3600AAE top load washer is
Could be a bearing, if a seal wore out, it should be putting grease spots on your clothes though. http://www.appliancepartspros.com/repair-help/maytag-washer-lat3600aae-repair/lat3600aae-noisy.html
2/27/2018 2:40:12 AM • Maytag LAT3600A... • Answered on Feb 27, 2018
Kenmore oasis makes loud noise when spinning
You can check the shock absorbers, maybe is not in good conditions.
12/23/2017 6:22:55 PM • Maytag LAT3600A... • Answered on Dec 23, 2017
2answers
Maytag performa washing machine will not run. No noise, what to c
test the capacitor
9/7/2016 7:47:02 PM • Maytag LAT3600A... • Answered on Sep 07, 2016
0answers
Washer will not work after filling it with water
Shawnie, sounds like your lid switch is giving you problems. They revised the switch, it comes in a kit with instructions. Part number 12001908. Take a small screw driver with the lid closed and push in on the actuator to verify that this is the problem. Catriver..post back.
2/14/2014 6:25:37 PM • Maytag LAT3600A... • Answered on Feb 14, 2014
Machine comes on fills with water but will not advance
This symptom of the unit filing and then not washing can be caused by few things.
1. The water level pressure switch not making contact to the motor control circuit but shutting off the water valve. There should be 120 VAC on the yellow wire of the water level control pressure switch when the fill level has reached the correct level.
2. An internal timer contact problem for the motor control circuit. Power for the timer motor should also be present on terminal 14 of the timer.
3. A defective motor speed switch. There should also be power on the yellow wire going to the motor.
All of the above power is sourced via the lid switch.
Black wire is power in. You know you have power in... as it fills.
Schematic:
http://www.appliancepartspros.com/partsearch/frame_diagram.aspx?diagram_id=1330708&pkw_=basket&model_id=5170285&NewWindow=1
This is going to take a meter to isolate the problem. Changing parts can get expensive but treouble shooting with a meter will result in determining where the failure has occurred.
Thanks for using FixYa.
Kelly
12/13/2013 5:48:58 PM • Maytag LAT3600A... • Answered on Dec 13, 2013
0answers
Lat3914aae
Be the first to answer 6/26/2013 6:49:44 PM • Maytag LAT3600A... • Posted on Jun 26, 2013Be the first to answer
Makes a horrible noise when spinning out
Changing the belt should help.
6/26/2013 2:57:33 AM • Maytag LAT3600A... • Answered on Jun 26, 2013
Maytag washer model lat9406aae totaly dead is there a fuse in the washer?
If this does not work on any cycle then make sure you have electricity at your outlet as there is no fuse for this unit.If you have power but it will not work in any cycle then you most likely need a new timer.If the unit will fill and wash but not spin or drain then you most likely need a lid switch.
4/5/2013 2:41:15 PM • Maytag LAT3600A... • Answered on Apr 05, 2013
MY whirlpool WASHER MACHINE FILLS WITH WATER BUT DOES NOT WORK AFTER THAT. IT DOES MAKE SMALL NOISE LIKE MOTOR BUT DOES NOT WORK.
1 PointsMY whirlpool WASHER MACHINE FILLS WITH WATER BUT DOES NOT WORK AFTER THAT. IT DOES MAKE SMALL NOISE LIKE MOTOR BUT DOES NOT WORK
11/27/2012 10:09:50 PM • Maytag LAT3600A... • Answered on Nov 27, 2012
3answers
The washer is not spinning well...Clothes are
Hello, when the clothes are partly wet when cycle is complete then check these.
1. Motor coupler
2. Spin cycle
MOTOR COUPLER; To test the motor coupler, restart the washer in it's spin cycle,let the machine runs for a minutes and then open the lid and notice if the tub is spinning: if it's spinning when you lift the lid that means the coupler is fine and if it doesn't spin that means you have to replace it.
SPIN CYCLE: If the washer doesn't reach it's proper spin speed,the cloth may be wet at the end of the cycle,check to be if the load is properly balanced and run a spin cycle again,if the clothes are still wet, you may have a worn or loose belt which you have to replace.
Thanks
10/7/2012 4:53:11 PM • Maytag LAT3600A... • Answered on Oct 07, 2012
0answers
Maytag Washer Model LAT9416AAE -
The usual charge when i have repaired that is around $375
in addation to the seal a tub bearing would be required since the seal has leaked it very likely has rusted the bearing. To replace those both the inner and outer tub have to come apart,the breakdown would be
Parts--$150
Service Fee $75
Labor $100
labor and service fees vary from company to company and that is probably low,yet it is a great washer and may be well worth investing in to repair
8/6/2011 9:43:04 PM • Maytag LAT3600A... • Answered on Aug 06, 2011
Water leaks when filling
Use a putty knife at the top front corners to release the spring catches. Lift up the top. Examine the plastic thing that delivers the water to the tub, it may be cracked or out of place.
8/6/2011 7:21:04 PM • Maytag LAT3600A... • Answered on Aug 06, 2011
Maytag LAT3600A Top Load Washer Logo
143 questions posted
Top Maytag Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Maytag Washing Machines
Most Popular Question
maytag washer model lat9416aae
  • Washing Machines
