20 Most Recent
Gemini Sound Products P07 2-Channel Amplifier Questions & Answers
Fuses for P-07
the fuse you need is a t4al 250v
this is a common slow blow 250v 4amp fuse.
You can get them at RadioShack
GEMINI PXB 1600
Hi...
Best places
www.digikey.com
or
www.mouser.com
No minimums.
Rate my help please if it helps
Thanks
Gem sound dj amp blows fuses on the right side
There is a problem with the output section. The most common cause is shorted output transistors. This unit should go in for service. Without seeing the unit and testing it, I can't indicate all of the defective parts. You should expect a parts cost between $25-$45.
Dan
Gemini p-07 amp board fault
Its better to get the schematic diagram or a similar one to be sure, but the reason for a blow up may have to do with a s/c along the line.
