20 Most Recent Electrolux Freezer Kelvinator Single Door Hardening Cabinet Flash Freezer Questions & Answers
Fridge is set at 6degrees but is freezing everything in the fridge
Change thermostat .
11/1/2014 9:22:52 PM • Electrolux... • Answered on Nov 01, 2014
The fringe section of my Kelvinator 500 twin air
http://www.fixya.com/TipsAndTricks/posttipandtrick.aspx?thid=8399718 try this.
2/22/2011 1:03:17 PM • Electrolux... • Answered on Feb 22, 2011
0answers
The fridge part of this integrated fridge/freezer
You will have to make an observation to see if the fan motor is working or not. If so then you will have to checck the incoming voltage to the fan motor so as to confirm that the fan motor is faulty.
If so the recurrance of the fan motor could be due to water condensation into the motor which is not suited for the purpose.
If the fridge is under warranty this complaint must be made to the delearship for a possible manufacturring defect if the fan motor has failed again, so that a new version of motor is installed that can withstand the conditions. ..
10/28/2010 12:05:49 PM • Electrolux... • Answered on Oct 28, 2010
I have a 1958 kelvinator upright freezer that has
It shows that it is plugged in.It is a power indicator light.
9/16/2010 4:41:11 AM • Electrolux... • Answered on Sep 16, 2010
I have a Kelvinator upright freezer model
You will be okay as long as the garage does not go below freezing. If the fridge gets that cold it could start to have problems.
heatman101
8/19/2010 8:04:08 PM • Electrolux... • Answered on Aug 19, 2010
My frost free freezer keeps frosting up
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
6/3/2010 12:09:29 AM • Electrolux... • Answered on Jun 03, 2010
Both red and orange light on
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
4/21/2010 9:31:58 AM • Electrolux... • Answered on Apr 21, 2010
Our frigide is defrosting water into the bottom
you have a clogged defrost drain. when y our unit goes into defrost, the water that is supposed to go down a tube from your freezer down to the bottom outside of the unit, into a pan to evaporate, instead is going into your fridge etc. This drain needs to be cleared. I would not recommend doing it yourself, you may cause further more expensive damage.
Refrigerator FAQ and Tips
3/25/2010 8:36:37 PM • Electrolux... • Answered on Mar 25, 2010
KELVINATOR REFRIGERATOR IF THE COILS ARE COVERED
yes.coils are the heart of the machine.adrian;;;
11/11/2009 2:46:56 AM • Electrolux... • Answered on Nov 11, 2009
Kelvinator Single Door Hardening Cabinet Flash Freezer fan
If the fan motor shaft is smooth with 1 flat spot the hub on the blade probably has a hex set screw that can be tightned with an allen wrench. If the fan motor shaft is threaded there should be a nut holding the blade on. Also yur motor bearings could be going bad causing vibration which damages the fan blade.
9/22/2009 10:21:24 PM • Electrolux... • Answered on Sep 22, 2009
Stopped freezing all the sudden. it remains cold but most items a
switch off your refrigerator for at least 5 hrs. than again switch it on.. if your problem is not solved that it is sure that your thermostart is not working........please replce it
5/14/2009 10:30:31 AM • Electrolux... • Answered on May 14, 2009
Suspect blocked frost free pipe
yep sounds like you have a bloked drain, u may have to pull the freezer apart inside to fix it
5/1/2009 10:31:27 AM • Electrolux... • Answered on May 01, 2009
2answers
I have an Electrolux upright freezer glfh21f8hwb. It runs for about 3 days, then shuts off and displays error code OF and shuts off. If I reset it with the temp control, it starts again and freezes, but shuts off again in a few days. I just replaced the controller and capacitor with OEM Electrolux parts because it wasn't working at all. With those new parts, it started working again, but now I am getting the OF code. Please advise.
Sorry but I know nothing of the new-fangled fridges and freezers with their codes, but what does tend to stop an appliance that otherwise works well is a lack of cooling air around the motor/compressor unit and when the unit works harder during the summer or in the depths of winter when the heating is full on the thermal protection can cut power to the unit. Cleaning dust and fluff, ensuring all the power connections are clean and tight and not generating heat and ensuring there is adequate air space between the wall and the unit.
9/19/2020 9:15:13 PM • Electrolux... • Answered on Sep 19, 2020
How do I disconnect the electrical to remove door on Electrolux upright freezer modelFFU21F5HWM
https://youtu.be/FzZS8TbGVxQ
10/13/2018 5:28:18 PM • Electrolux... • Answered on Oct 13, 2018
I have an Electrolux Intuition Chest Freezer. The
you need to clean the condensor coils with a brush or compressed air
7/12/2018 7:05:35 PM • Electrolux... • Answered on Jul 12, 2018
FRT21BW8DW0
https://www.repairclinic.com/RepairHelp/Refrigerator-Repair-Help Use this link for future/current reference I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
12/17/2017 4:22:36 PM • Electrolux... • Answered on Dec 17, 2017
Electrolux ER 7526 Bfridge freezer
https://www.repairclinic.com/RepairHelp/Refrigerator-Repair-Help This link will help you with parts. You will probably need to replace your cold control. I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
12/16/2017 2:07:51 PM • Electrolux... • Answered on Dec 16, 2017
Freezers Logo
Popular Tags
18 questions posted
Top Electrolux Freezers Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you an Electrolux Freezer Expert? Answer questions, earn points and help others
View Most Popular
Electrolux Freezers
  • Electrolux Freezers
Most Popular Question
  • Freezers
