20 Most Recent
Panasonic PV-GS36 MiniDV Digital Camcorder Questions & Answers
Can this camera be compatible with windows 7?
Not compatible or not working well with windows 7?
(make your program/application run with windows 7)
Maybe, It doesn't work because the driver/application you installed is
for other versions of operating system. I am also using windows 7 like
you so don't you worry, You can still use your old installer/driver from
other versions of operating systems. Just remember that before
installing any program in a windows 7 Operating System Computer, Use
"troubleshoot compatibility". Right Click the Icon of your program
installer/application first, then choose "troubleshoot compatibility".
This will allow you to choose on what type operating system your program
will run. Just reply back if it still doesn't work.:D rate and vote
for me:))
12/6/2010 2:12:43 PM •
Panasonic...
Answered
on Dec 06, 2010
Gs36 tape door doesnt open
In case anybody read this.... I have a GS-36 that would not eject the tape. I removed all the screws from the bottom and pulled the bottom plate off. Then I fidgeted with the mechanism near the eject button towards the front of the camera. In my case it had just become stuck and needed to be gently pried open. Tested it a bunch of times with tape - seems to be o.k.!
7/2/2009 7:36:45 PM •
Panasonic...
Answered
on Jul 02, 2009
How to connect Panasonic GS-36 to PC
Your camera has a 4 pin port on the side of it next to the USB port.....depending on the type of firewire connector on your computer will determine what type of 1394 cable you will need to connect the PC to the camera. Your computer could have a 6 pin or 9 pin connector (I'm betting it has a 6 pin). Get a 1394 cable that is 4 pin to 6 pin and you should be able to connect the two together....that's how I did it with my tower PC and to my laptop with a firewire PCMCIA card.
3/16/2009 11:01:25 PM •
Panasonic...
Answered
on Mar 16, 2009
Where can I download an XP driver for my Panasonic PV-SD5000 camera?
Look for the driver compatible with XP at these sites. You can download the driver for your Panasonic PV-SD5000 camera from the following sources:
Internet Archive: You can download the driver files for the Panasonic Palmcam PV-SD5000 camera from the Internet Archive website . The files are available for free download and include drivers for Windows XP.
Solvusoft: You can download the latest drivers for your Panasonic SuperDisk PalmCam PV-SD5000 camera from the Solvusoft website. The drivers are updated daily and are certified by Microsoft.
HelpDrivers: You can download the driver for your Panasonic PV-SD5000 camera from the HelpDrivers website. The website provides a step-by-step guide on how to download and install the driver.
It is important to download the correct driver for your camera and operating system to ensure proper functionality.
Manual Panasonic PV-L4530
Here it is and it is also available on the manufacturers web site.
https://www.manualslib.com/products/Panasonic-Pvl453d-Vhs-C-Camcorder-2785065.html
