20 Most Recent
Maytag SAV2655A Top Load Washer Questions & Answers
Drain hose popping out
loop your drain hose into a J shape, the hook part about 8 inches long and ziptie it so t stays that way . then put it in the drain pipe in he wll.
Washer is very noisy even when empty when the
you need to replace the bearing and seal assy. this is rather involved and you need to be mechanically inclined. the bearing seal kit goes for around 70.00 deplending on where you live and who you know.
WATER LEAKING FROM ABOVE THE WHAT APPEARS TO BE
Your center seal where the shaft goes through the tub to the transmission is bad and is letting water leak bye it. I would not repair the machine it will run you $350 to $600 to fix you have to buy a bearing kit which has the seal in it and the labor involved is a lot normally 4-5 hours to complete the job I would not attempt this on my own unless you know what your doing. I would start looking for a good quality used one or a new one sorry for the trouble hope this helps.
The agitator is very sluggish and water is leaking
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
My washer agitates drains but wont spin until i
sounds like your timer is bad this is the selector for spin wash ect... This is not a hard repair the back comes off the back top of the washer to exspose the elect controls you will need to unplug it then pull off the knobs and remove the two screws. Make sure to unplug the unit from electricity first. good luck.
Our SAV4655EWN it is spinning through the wash
This factory service manual covers your unit.
Cut and pate the pdf link.
Refer to page 106 section 9-4 for possible problems.
http://www.servicematters.com/maytag_library/docs/16023083.pdf
Maytag washer sav365zaww
LARRY...I HAVE THE SAME MODEL AND THE SAME PROBLEM JUST STARTED FOR THE 3RD TIME. CALLED THE REPAIRMAN THE FIRST TIME, MYSELF THE 2ND. MINE IS A BROKEN(IN TWO) BRAKE PAD. THERE ARE THREE OF THEM. REMOVE 2 SCREWS AT VERY BOTTOM OF WASHER FRONT AND REMOVE PANEL. YOU CAN GET TO THE 2 FRONT PADS FROM THERE ALTHOUGH TIGHT FIT. I ALSO READ THEY SHOULD HAVE CLEAR LITHIUM GREASE ON THEM, ALTHOUGH THIS DOESN'T MAKE SENSE TO ME. GONNA GO DO MINE AGAIN...GOOD LUCK....KHRIS
Won't spin, agitator won't turn. Repair it or just
Hello,if your washer won't spin first check to see if the motor is running, then proceed as follow.
1. If the motor is running, your washer probably has a frozen pump pulley or broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely or if it is frozen or stiff replace it.
If the pump belt is broken or looks quite warm, replace it but be sure to check the pump pulley before you change the belt.
AGITATOR: If the agitator won't turn, the likely cause is "Lid Switch" because if the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Thanks
Water is pouring out the bottom when emptying
Is you water discharge hose still connected to the drain in the wall? If not, place it in the drain and make sure it is secured and won't pop back out of the drain (tie it down to faucet next to drain). If the hose is connected to the drain, then the hose must have came undone inside the washer, or has a crack in it. Check condition of hose and look inside washer to make sure it is connected.
