20 Most Recent
Maytag Neptune MAH7500WH Front Load Washer Questions & Answers
Maytag Neptune MAH7500AWW Speed Indication Error - Won't spin up...
Sorry, I cannot solve this. I just wanted to post a couple of useful tips for anyone else out there who happens to be diagnosing their MAH7500AWW.
1. You can put the washing machine into service mode by pressing the <back> and <help> buttons for 5 seconds and then releasing.
2. There is a large folded troubleshooting schematic located under the top console. You have to remove a few screws and lift it up to pull it out.
My maytag Neptune washer mah7500 panel doesn't light up, but still works
Thought it was the door switch/grounding issues/loose wire, etc. Finally found that there was a bad capacitor on the circuit board. It was a 15 cent part that, when replaced, caused all the non-start/power failure indication issues to go away. I've included a picture of the bad part - you can see the slight bulge on the top of the capacitor and a little leakage. Hope this helps.
My washer is just dead.
Check to see if the main panel circuit breaker is popped by switching it off and then back on again and there should be some resistance when switching it back on again. Next you would need to check the outlet by plugging something like a light that you know works into it and then check the washer plug and wire cord to see if there is a problem there and if no success there you will need some present who knows more about appliances and can check internally in the appliance.
Will not spin
Does the machine attempt to spin or wash? These are the last of the lawsuit generation where the motor control board circuitry failed, most likely blowing the fuse. Unplug the unit from the wall, open the door and remove the 2 screws on the left and right (2 will be holding the hinges on) close the door and gently tug on the top corners of the front panes, look down to the lower right floor of the inside of the unit, does your motor control board have the white or clear plastic sheet folded over it, or it is a solid yellowish plastic housing? The control board with the white or clear plastic sheet is the old style, and mote likely needs to be replaced. there is an on board fuse that will blow. The parts needed are serial number dependent, so your serial number will need to be provided. Pleazer Appliance...
Old Style
New style
My Neptune does not extract
I am having the same problem, and have found that the door lock light is not on, and that the door lock does not seem to be working. This would keep the machine from spinning.
Is your door lock light on?
Grease spots on clothes
Your drum support bracket grease shaft seal (which will require a new Lip Seal Kit #12002022) is dead and potentialy the two shaft bearing are at risk. Parts cost retail approx. $100 or so. Labor, Lookout...
I'm fighting this issue for the second time.......
Bill B.
"Continous Unbalance"
we had the same problem. had a tech come out, he said it was the control board/motor. Never heard back from him with a quote to finish the repair (but he never billed me for the visit either, so hesitant to call him back!!), so used the 'diagnosis' and bought it on-line, $175. Husband installed, did NOT fix the problem. did more investigating on-line, decided to spend under $20 (eBay) on this: Maytag Washer Unbalance Switch #22003302 - cheaper than calling a repair person, so worth a try. Husband installed, FIXED!
Washer wont drain
Clear the pump filter, normally found via the square door at the front of your washer. If that fails then your pump may have gone.
Maytag Neptune MAH8700A tha detergent drawer is filling up with water and running out of the drawer onto the floor not going into the tub.
see this causes and fix it. God bless you
Belt, Water Pump
If the washer won't drain the pump belt might
have broken or might have worn out. Check the belt and replace if it
shows signs of excessive wear.
Drain Pump
If the washer won't drain water the drain
pump might be defective. It's also common for a small sock or other
article of clothing to get caught in the drain pump or in the drain
hose. Check both for an obstruction before replacing the pump.
Clogged Pump or Hose
If the washer won't drain there might be a
clogged pump or hose. It's common for small socks or other small
clothing items to get into the water drain system and clog the hose
leading to the pump or the pump itself. Remove the hoses from the pump
in order to remove the article of clothing. Keep in mind that any water
in the washer will pour out of the hoses when removed.
Drive Belt
If the washer won't drain, should check the
drive belt. If the belt is broken or if it isn't tight on the pulleys
the washer won't drain properly, if at all.
Lid Switch Assembly
If the washer won't drain the lid switch
assembly might be defective. This is a very common problem. The lid
switch assembly can fail either mechanically or electrically. Test any
electrical switches with an Ohm meter for continuity. The switches
should have continuity according to their design.
Door Lock Motor and Switch Assembly
If the washer won't drain the door lock
assembly should be checked. The door lock can fail either mechanically
or electrically. Test any switches on the door lock with an Ohm meter.
The switches should have continuity according to their design.
Drain Hose
If the washer won't drain water check the
drain hose. Be sure the hose did not get kinked behind the washer. Also,
remove the hose from the pump and check it for obstructions.
Coin Trap
If the washer won't drain the coin trap may
be clogged. This washer is equipped with a device near the water pump
called a coin trap. The purpose of this device is to trap any foreign
materials that make their way down the drain. Normally, the coin trap
can be accessed through an access panel. It is designed with the
homeowner in mind and is normally easy to clean out.
The washer did not spin due to continuous inbalance
Check the unbalance sensor, or inertial switch, it should be N.C., or normally closed, giving a "balanced" signal back to the control board. My unit had no continuity even when there was no out of balance, or severe shaking. If you have a voltmeter this can be tested by disconnecting the wires to the sensor and setting the meter to Ohms, it should be very low, 0-5 ohms. If it is higher than this the contacts are bad. I fixed mine by running a small electrical load through the switch, a 100 watt light bulb, with power cord that I rigged up. I shook the sensor several times until the lightbulb had power when the switch was still. This "cleaned" the contacts by running the 100 watts of power through the contacts and creating a spark. Or you could jumper the wires together and see if the unbalance condition goes away; if so, replace the switch.
I have a maytag neptune
Hello
& Welcome to FixYa
You
will have to take it apart completely, this repair manual will help you in doing
so. Please get back to me if you have any other questions.
Kevin
Washer Won't spin at full strength.
Anney, there has been so many service flashes on these Neptunes. One is the redesign of the motor and motor controller. What you are describing sounds like a defective motor control board. There are tests that can be made but you would have to know how to use a meter. If I had to make a call on this with out seeing the machine, I would tend to believe it is the motor control board. You might want to call Maytag and see if there is any service flashes that would address your problem. In looking up the model you posted, I see at least 13 issues they had in the design of this model...Catriver...post back.
Bleach and fabric softener dispenser will not
hello, so you cleaned out the dispenser and cleared the holes under the dispenser cap. low water pressure or blocked fill valve screens can cause this problem also. remove the hoses from the back and make sure the screens are not blocked. hope this helps..ken
Doesnt work
need more description. if it is getting power, but still appears dead, it is probably the controller board.
try to find an old radio repair shop to get it fixed, sounds like a simple power supply issue.
good luck
