20 Most Recent
Canon EOS Rebel K2 with 28-90 lens 35mm Film Camera Questions & Answers
Flash stopped working
No, the battery is the same as you use to make all the other pictures. To check if your flash really does not work, please put the camera in automatic (green camera symbol and hold your hand in front of the lens while pressing the shutter button (to make it look dark) The flash should pop up and should go off.
When you don't put the camera in auto, it expects you to tell if the flash should fire or not.
If your battery is bad, or almost empty, it can't charge the flash, so it won't fire either.
I have a canon 28-90mm
Welcome to Fixya
Err 99 could means several different things, such as... Memory Card, Lens or Lens contacts....
Here's what you can try:
Remove the memory card an enable "shooting with out memory card" and see if you still get the error. If it works your memory card is bad. Try another lens if you can. Clean the lens contacts with a pencil eraser (be careful not to get eraser dust in the camera body or in the lens). Worst case scenario is, Err 99 could be related to the shutter failing which would mean a trip to Canon.
Thanks If you need further help, reach me via phone at
https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
I just purchased a Canon EOS Rebel K2 35 MM film
The Rebel K2 has the Canon EF mount. It is compatible with any EF lenses except the EF-S series. It will also work with third-party lenses that are compatible with the Canon EF series.
You can see the entire current line of Canon lenses (including the EF-S series) at
http://www.usa.canon.com/cusa/consumer/products/cameras/ef_lens_lineup
Canon EOS Rebel K2 constant low battery indicator light
Canon also uses the low battery Icon as a generic error code. Try taking the lens off the camera. If this fixes the problem the lens needs a repair (most likely the aperture unit). If not then the camera needs the repair (either the shutter or dc-dc converter circuit).
Canon eos rebel k2
That all depends on what you have your settings for. If you are not using the program mode, you'll need to make sure to check your Aperature and Shutter speed. Adjusting these might make your pictures come out better. Make sure to check your light meter, the needle or indicator should be in the middle for best results.
Canon 12x36 is ii stabilization is not working properly. Stabilization
tends to want to stray.
Hello, I think dust, smudges, or fingerprints on the lenses can affect image quality and stabilization performance. Use a soft, lint-free cloth or lens cleaning solution to gently clean the lenses of your binoculars. Make sure not to apply excessive pressure or use abrasive materials that could scratch the lens surface. Moreover, when using image-stabilized binoculars, it's important to hold them steadily and avoid sudden movements. Rest your elbows on a stable surface or use a tripod if possible to minimize hand tremors. Ensure that you're using proper stabilization techniques to maximize the effectiveness of the stabilization feature.
