20 Most Recent Canon imageCLASS D320 Digital Copier Questions & Answers
2answers
ALL COPIES BLANK. NOT LOW
probably the problem is in laser shuter or toner cartridge pin in toner holder. But when you try to copy, when paper goes to the drum, open the right cover and produce paper jam, now look at drum for image, if on drum isnt image its laser problem...
If the laser shuter is faulty, these means that when you close the right door, the nose on door doesn't lift the laser shuter and so the laser unit cant write on drum.
If the toner crg. pin is faulty, when you insert toner in holder inside the copier, on right side of toner holder is small circle with pin that contacts the toner and gives voltage. You can apply some wd40 to that circle, that goes in and out when you open or close door.
But, probably is laser shuter... to check him you need to dismantle the copier.
Hope that helps!
1/21/2023 10:39:55 PM • Canon imageCLASS... • Answered on Jan 21, 2023
Install cartridge message displaying on my machine
When your cartridge is not adjust properly.
install your old cartridge.If this massage again may be your machine .Right side drum charge lock not adjust.Or machine ready so problem on cartridge.
Cartridge part no T series toner cartridge SG 35 is appropriate model.
6/11/2017 1:46:29 AM • Canon imageCLASS... • Answered on Jun 11, 2017
2answers
Light Copies Canon imageCLASS D320
hi im jules_09,check the developer,if its past over 60,000 copies if its over 60,000 copies you need to change the developer along with the opc drum and cleaning blade or roller,all copiers need to be replaced with new developer,opc drum and cleanign blade or roller when it reach its copy life,that may be the cause of light copy of print
5/22/2017 6:10:29 PM • Canon imageCLASS... • Answered on May 22, 2017
Canon ir2020-seystm err e354 please tel me what
E354
•When turning ON the power, inconsistency of the serial No. of
the serial number PCB and that of the controller PCB
(SRAM)/counter memory is detected.
•When turning ON the power, it is detected that no serial
numbers are assigned to the serial number PCB and the
controller PCB (SRAM)/ counter memory.are you trying to change the counter board this not possible bec the serial no of the machine is embedded on the counter board so no counter tampering allowed
1/10/2017 12:33:22 PM • Canon imageCLASS... • Answered on Jan 10, 2017
Supply rec. paper tray:ltr
1) unplug machine from power supply.
2) Under printer properties, select custom paper size and set it on A4 if you use A4.
3) Power on the machine and then try to print.
Hope that helped
11/17/2016 12:27:13 PM • Canon imageCLASS... • Answered on Nov 17, 2016
2answers
How to remove paper jams?
I am giving the link to your canon's service manual which has remedies for all the problems........
printer1.blogspot.com/2008/06/copier-canon-ir2020-2016-service-manual.html
password for rar : printer1.blogspot.com
Hope my info is useful......
9/3/2016 8:33:42 AM • Canon imageCLASS... • Answered on Sep 03, 2016
0answers
Canon d320 service manual
Hello friend, you can find the canon imageCLASS D320 service manual in below link: Canon D320 service manual: http://goo.gl/fjS4rM Thanks
12/2/2014 2:21:42 PM • Canon imageCLASS... • Answered on Dec 02, 2014
Canon imageCLASS D320 Digital Copier Logo
210 questions posted
old marine
old marine
ZJ Limited
ZJ Limited
View Most Popular
  • Canon Office Equipment & Supplies
Most Popular Question
remove paper jams
  • Office Equipment & Supplies
