20 Most Recent Canon Digital Rebel XT / EOS 350D Digital Camera with EF-S 17-85mm IS Lens Questions & Answers
How to switch video mode on canon eos 350d
Hi,I doubt about your camera having a Video mode. However you can check these settings for your Camera in detail.Click on the link -> Camera Settings Regards,Suhail
5/30/2019 11:38:27 AM • Canon Digital... • Answered on May 30, 2019
How do i restore default setting
Go to manual mode (very important) Go to the last tab Select "Clear all camera settings" Select "Clear all custom Functions" by the way, have you tried to upgrade your camera?
2/18/2015 7:24:03 AM • Canon Digital... • Answered on Feb 18, 2015
Canon EOS 350D error 5
Does the flash open? Open the flash and try alcohol or purell hand sanitizer on the hinges and release mechanism. Let it soak in and work it in by moving the flash hood repeatedly up and down Also check the canon eos 350d service manual from below link: http://goo.gl/rnauJZ it will save you money thanks
11/25/2014 2:53:07 PM • Canon Digital... • Answered on Nov 25, 2014
Wont keep date
Replace the data/time battery as described on page 38 of this manual.
1/27/2013 5:05:37 PM • Canon Digital... • Answered on Jan 27, 2013
The camera eill not charge
It's not supposed to. The camera comes with a battery charger. Take the battery pack out of the camera, put it into the charger, and plug the charger into a power outlet.
4/4/2011 5:09:28 PM • Canon Digital... • Answered on Apr 04, 2011
Switched to new computer. downloaded latest canon
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Canon ZoomBrowser or any other photo cataloging program.
4/2/2011 6:08:10 AM • Canon Digital... • Answered on Apr 02, 2011
Error 5
Hello the error 5 is a pop up flash issue and normally appears if your pop up flash is not opening properly. Try wiggling the flash open but do it gently! then clean the area it could simply be grit or dirt has got into the mechanism... let me know if this helps....
12/22/2010 3:32:45 AM • Canon Digital... • Answered on Dec 22, 2010
Have a eos350d camera ,the flash is not popping-up
If you're sure the click is from engaging the flash I suspect the spring or holding mechanism is stuck, maybe dust, dirt somewhere inthere. Can you lift the flash mechanism by hand after the click? If so, you can try and clean it with compressed air.
10/29/2010 7:36:55 PM • Canon Digital... • Answered on Oct 29, 2010
Put a new fully charged battery in - the camera
It is due to some kind of electrical contact failure.
For more details and common causes of Err 99 read the following article:
http://www.lensrentals.com/news/2008.12.31/canon-err99
5/17/2010 11:40:11 PM • Canon Digital... • Answered on May 17, 2010
Cant connect
Try going to Canon's website and updating your drivers AND you firmware.
5/9/2010 11:05:46 PM • Canon Digital... • Answered on May 09, 2010
I have a Canon 350d camera EF18 - 55mm Lence ,
this is what the canon people say to do for error 99
Read this!!!
The guy at tech support listened and then told me that the lens contacts were dirty and to get a pencil with an eraser on the end, just a regular old pencil with a red rubber eraser. Detach the lens from the camera, hold it so that the lens’ gold contacts are pointing down and lightly erase their exposed surface, cleaning them of any hand oil that might have gotten on them.
Do the same thing with the gold contacts inside the camera body. This is a bit harder but it’s doable: just hold camera so lens opening points down so no gunk falls in. Erase lightly. I used a lens cloth and dabbed at the contacts rather than blow them so as not to blow the erasings inside the camera.
I did this to each of my three lenses just to be sure. Lo and behold, it worked good luck have a nice day!!! :) :) :)
4/8/2010 8:57:22 PM • Canon Digital... • Answered on Apr 08, 2010
My computer stoped recognizing my
Time to start using a card reader.
3/29/2010 4:17:22 AM • Canon Digital... • Answered on Mar 29, 2010
How is change shutter speed for canon 350 D
In either Tv or M mode, simply turn the command dial. In Program AE mode, press the shutter release button halfway and then turn the command dial to shift to different equivalent exposures.
3/22/2010 5:08:17 PM • Canon Digital... • Answered on Mar 22, 2010
tip
Canon EOS 350D digital camera Manual(PDF)
Hello
Here is a great tip explaining where you will be able to find and download an updated PDF version of this manual. This site will also provide you with a huge database of other product user manuals. Click HERE to find out exactly how to download the manual.
At this link you will also be able to read reviews on this product, compare prices, and get a general overview. There will also be a full spec sheet on this product.
Click HERE to navigate to Retrevo, where you will be able to download the manual.
Also feel free to visit Canon's official website.
I really hope this can be of help. Please rate accordingly.
Kind regards
Andrea
Canon Digital Rebel XT / EOS 350D Digital Camera with EF-S 17-85mm IS Lens Logo
58 questions posted
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
View Most Popular
Rebel Canon
  • Rebel Canon
Most Popular Question
wont keep date
  • Cameras
