20 Most Recent
IBM eServer xSeries 100 Questions & Answers
How to install Windows 7 graphics driver for the
I think the xseries 100 does not support windows 7, I think XP is the latest operating system it can handle, many websites advertise for driver solution will offer you a solution but I am not sure they can deliver, my advise would be to contact IBM and see if anything can be done to help. Good Luck
IBM xSeries 3550 M3. One fan has failed. While waiting for a replacement can I stop the server from shutting down automatically?
Assuming that this is resolved as it appears to be an old, time-sensitive issue.
Although I would say that what you're asking would have been a design choice on IBM's part. The BMC would dictate fan curve and if one of the fans is not spinning at the minimal RPM - as specified in that fan curve - then it would obviously shut the system down to protect it from heat damage.
You may be able to adjust this using various commands in the BMC but I am not familiar with IBM's hardware. (Which is likely different in the same way that Dell's iDRAC differs from HP's iLO, etc.)
I'd say it's unlikely either way.
I9990650
I would check the firmware/bios as these had a known issue.
Check with IBM for the latest firmware and BIOS.
Update me if this does not resolve the problem.
Howto clear log on server ibm
Server is model is not mentioned.
You can clear logs by this way..
1: Get into BIOS and there you could see server logs. Clear those logs
2: Get into IMM and you can find logs there. Clear those logs (This is applicable to servers with IMM and Uefi firmwares)
3: Get into BIOS and find out IPMI logs. Its under Advanced settings.
Clear those (This is applicable for older x series machines with BIOS firmwares)
Thanks
Exchange 2003 server
Guide events have changed the identification protocol and a refreshment of the input data to the Event ID structure will fix the problem. This must be done within 24 hours of the last formal event or else the system will crash and no longer be salvable.
Cpu fan error
Well it usally means the fan is bad it may work and keep your CPU cool but it can still send the code just replace the fan
