Try adding bicarb of soda/baking soda and vinegar in the detergent dispenser. Bicarb fizzes off hardened particles and vinegar strips off grease and aids rinsing.
This is an old question, but my answer may help someone. I experienced the same after having had a new dishwasher installed. Switched it on, it made all the humming noises, heard running water then nothing. Simple solution was on checking the plastic plug was still in the drain spigot and the hose had been connected over the top of it so no water could drain away.
The arms do accumulate gunk that clogs the sprayers. Disassembly, cleaning and reassembly are not difficult.
However, I think that your problem may be in the main filter and strainer, which are located around the base of the bottom arm. Download the diagram of the model and remove, clean and reassemble. My bet is that you'll find a layer of sediment in the filter that can be removed with a soft brush and running water.
If you have pets that shed, be ready to find fur in the filter.
Before drawing any serious conclusions check wash arms for blockage in spray holes, < possibly slowing delivery of water pressure > it can be calcium from hard water.
I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying... Dishwasher Spray Arms not Spinning
you should check the heating element. if the water is not hot enough, the timer will not advance. crack open the door mid-cycle. let the water stop flying around. then open it all the way up. if you don't get a big ball of steam, you have an indication that your heating element may not be working properly. this is not too hard to check the resistance with a multimeter and then replace, if necessary. good luck
a pluged or should i say a partially pluged lower spray arm nozzle redirecting the water spray under the door causing it to spray water in a direction it shouldn't be, causing your leak. another spray arm could again have a partially pluged spray hole causing water to spray in a direction it shouldn't, or more forcefully so it blows past the door seal.. the float switch could be bad allowing an overfill, but thats usually more substantial. best of luck, ttfn
First,inspect the drain float. Make sure it rides on the micro switch correctly or it will not take on water.Check the float micro switch for continuity. Check for power at the water valve when it calls for water. Remove the wire harness from the timer and re-install it. Make sure you get a good tight fit,they can become loose over years of use. If that does not correct the problem I would suspect a bad timer.
I found this for you on YouTube. I don't think that you want to go to the extreme lengths that this guy did, but he does show how to disassemble the inside portion of your washer so you can get to the parts that need cleaning. This should get you back up and running, with sparkling dishes, and a big smile on your face! There are also oyher videos there, some selling products that may help.
I have an older (1990) Maytag dishwasher that had the same problem. In my case liquid dish soap had penetrated the seal and dried out causing the rotating cover shaft to freeze up.
Remove the door panel and then disconnect and remove the soap dispenser from the door. Make a diagram of the soap dispenser as you carefully disassemble it; there is a coil spring around the soap door axis. If you find a buildup on the door shaft or in the hole it rotates in or in the groove the door rides in, try removing the residue with a plastic scuffy pad after letting it soak in a lime scale remover (Lime Away) or some other cleaner. I think Jet Dry makes a dishwasher cleaner. Before you reassemble the dispenser, wipe a thin film of plumbers grease (available at Home Depot or Lowes) on the shaft.
If the door is free turning and doesn't appear to be bound up, then the problem may be with a heating element that expands when energized, allowing the door to open to the second soap compartment. An ohmmeter will be needed to test the thermal lock.
These jobs are fairly simple and should need only a Phillips screwdriver and a volt ohmmeter.
I suspect something hard like a fragment of chicken bone or a citrus seed is at the inlet to the drain pump (my favorite was a plastic pull strip from a frozen juice concentrate can - that was LOUD). Many dishwashers have a chopper similar to that in a garbage disposal right before the pump inlet, but some things like bone won't go through it. It could be something light enough to float and only hits the pump when the water level drops. You may have to remove the pump cover in the bottom of the dishwasher to find it. This would be a good time to clean any garbage out of the lower spray arm and check the spray arm bushing for excess wear.
5Found This HelpfulGeorge Doyle/Stockbyte/Getty images
Dishwater residue is a fairly common occurrence, and several things can cause it. Even the newest dishwashers may leave residue, and it might have nothing to do with the actual dishwasher function itself. However, there are things you can do to prevent, limit or completely remove dishwasher residue during every washing cycle.
Modern phosphate-free detergents are the main culprits when it comes to detergent residue. After every wash, many leave a slight whitish residue behind. After several washings, the residue becomes caked on and leaves a noticeable white tint to your dishes. Some dishwasher detergent brands are better than others, and either minimize residue or do not leave any. Once residue is present, however, the only way to remove it is by hand scrubbing or scraping.
Hard-Water Residue
Hard-water residue comes from non-softened water from your hot water tank. Non-softened water leaves a white tint on dishes, but no amount of scrubbing will remove it. Only by wiping a small patch of the dish with vinegar or lemon juice will you be able to ascertain whether the white residue left is hard water or detergent. The slight acidic action of the vinegar or lemon juice removes hard-water stains, but they have no effect on detergent residue.
Greasy Residue
If the dishes feel greasy when they come out of the dishwasher freshly washed, you are dealing with a greasy residue. There are two main reasons for this: either the detergent is not an effective grease remover, or the hot water inside of the dishwasher, either from the hot water tank or the dishwasher's heating elements, is not hot enough. Boosting the hot water temperature on the water tank may solve the problem, and a second wash cycle may be needed for the dishes. A preventive measure of running the dishwasher empty with a full load of detergent also removes the residue inside of the dishwasher.
Streaking and Spotting Residue
If you have spotting or streaking on your dishes, that may be a sign you need a rinse agent. Many modern dishwashers recommend a rinse agent to prevent spotting or streaking, and without one, your dishes will never be crystal clear or streak-free. The next time you do a dishwasher load, add a rinse agent. If the dishes come out spot- and streak-free, the problem is solved.
i don't know. sounds like a fault in the program. consider unplugging machine for 10 mintes. plug it back in and run a short wash to see if the program has reset itself. if not OK, call for repair estimate then decide if you can live with it as is,-- have someone try to repairit -- or replace it with a new one which may offer extended warranty for $$.
