20 Most Recent Intel D915GAV Motherboard Questions & Answers
My Intel D915GAG mobo works
Intel D 925 has sata 1 controller , therefor your sata 2 or 3 drive can be malfuncton with this old controller , pls connect the jumper to sata 1 speed limit position in your hard drive near the data connector
9/26/2017 5:08:18 PM • Intel D915GAV... • Answered on Sep 26, 2017
I'm trying to install WINDOWS SERVER 2008, and
boyboto
To be able to properly address your BSOD I will need some info from the BSOD. The link below will show you the info that I need.
http://www.fixya.com/support/r4443711-blue_screen_death_bsod_important_info
Thanks
Issken
10/12/2016 3:47:34 AM • Intel D915GAV... • Answered on Oct 12, 2016
I cannot have my asus board p4p800 accept one sata disk (where XP resides) plus one pata disk. All bios possibilities I have tried (enhanced mode, sata/sata+pata/pata) and master/slave positions on th
You should put the OS on an IDE drive. Then you can have the DVD player on an IDE controller. The SATA drives can be used for a RAID or a JBOD.
3/6/2014 9:05:27 AM • Intel D915GAV... • Answered on Mar 06, 2014
Intel d915gav motherboard equivalent mother boards for replacement
i use a d945gtp board works great with no problems ok.
11/29/2013 7:21:09 AM • Intel D915GAV... • Answered on Nov 29, 2013
2answers
Ddr ram sdram
If you mean you want to replace DDR RAM with DDR2 or DDR3 RAM, that is impossible. MBs are designed for one type and the sockets themselves are keyed differently and use different voltages.
11/8/2013 3:24:42 PM • Intel D915GAV... • Answered on Nov 08, 2013
manual
Intel 915G Motheboard Sound Problem
do you have 915G moterboard driver cd?
if yes then just run it in default way,
happy to help you
PCSN 24X7
9350224303, 9213999055, 9999713329.
10/5/2013 9:59:49 AM • Intel D915GAV... • Answered on Oct 05, 2013
Audio bus driver
6/21/2013 12:07:48 PM • Intel D915GAV... • Answered on Jun 21, 2013
Overheating and shut down d915grv
CPU/ Processor resources and due to the heavy processing the PC heats up. Excessive heat up beyond usual is alarming and PC shuts down by itself when the processor/ CPU temperature exceeds the safe temperature limit. There are mainly two reasons for heat up. Heating issue generally occurs due to fan failure, which may damage the system, if not checked properly. Another most likely cause of overheating is the dust present inside the PC, which clogs the fan and heat sink. 1. Make sure the fan is running. (if not, it needs replacement)2. Clean the fan and heat sink (thermal module). Take out the fan and heat sink. clean them with the help of tooth brush and put it back.3. Also, make sure that the PC is placed in a well ventilated environment and the air flow the the PC is correct.The procedure is very simple and I believe immediate action is required to prevent any damage to your machine and data.Hope it helps! Good Luck!Thanks for using Fixya!CreativeTECH
6/4/2013 12:15:23 PM • Intel D915GAV... • Answered on Jun 04, 2013
3answers
Sound driver for win 7
and the winner is ? not Nitin Bhattdiscontinued product.... another solution ?12_12_2012_1_15_04_pm.jpg
12/12/2012 1:17:28 PM • Intel D915GAV... • Answered on Dec 12, 2012
I recently upgraded my ram (2 days back) to 1gb on my intel d915gav motherboard, first it seemed to work fine, but now the Pc won't boot, with it connected?
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be even something as small as a faulty power lead or fan lead can cause you problems
computers need all of the data and power to travel through every working device and to have an end to be able work properly
make sure ram modules and cmos batteries have dust free secure seatings and cmos battery has charge some motherboards cmos batteries are soldered in
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail
check all power an data leads make sure they have dust free secure connections
cd/dvd floppy drives need to have current go through make sure these drives are working
check you CPU make sure its securely seated and has thermal grease hope this helps
7/10/2012 6:09:59 AM • Intel D915GAV... • Answered on Jul 10, 2012
My pc mobo is intel 915gav. processor is P4 pinless running with 1 gb 400 bus ram..after a new installation of win xp i worked hours continously..but in in next morning when i turn on pc after running
HelloThere will be a thermally conductive paste [Heat sink compount], a white tooth paste like substance, must be applied between the heatsink and the CPU. It is a must. If you have replaced, or unlocked the heat sink metal, and haven't applied this thermally conductive paste, proper heat transfer from CPU and the metal heatsink will take place, and the CPU will overheat, and finally go out.Music videos are large files, which apply a great load to CPU, as processing video is a great task for CPU. Temperature must be below 40 degree centegreade, at any instant.Just unlock the heatsink lock, take out the CPU heat sink out, and apply some heatsink compound [silicon grease] and retry. If you hear a beep sound after 3 seconds or so, after swithch ON the system, you have won. OK.http://www.dataentryjobs.us/67948.html
2/22/2012 4:48:53 PM • Intel D915GAV... • Answered on Feb 22, 2012
I have installed t sound driver.. but i can hear a constant sound whenever i use it and if i talk over t headfones even the other side who is hearing me can hear the noise also... how can i solve this
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good or you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems be sure to wear an anti static earth strap before touching anything inside your computer try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your SOUND CARD dust causes static to build up in a computer causing it to overheat any many other problems hope this helps
2/14/2012 9:31:51 PM • Intel D915GAV... • Answered on Feb 14, 2012
2answers
Hi, Am
place the largest RAM closest cpu
hope this helps
2/11/2012 4:02:12 PM • Intel D915GAV... • Answered on Feb 11, 2012
9answers
Driver
Intel D915 onboard Audio, Video installation driver
12/17/2011 2:34:21 PM • Intel D915GAV... • Answered on Dec 17, 2011
I modules testing in Intel D915GAV Motherboard i
Sir
Restart your PC then sudden press DELETE key
10/4/2011 11:58:32 AM • Intel D915GAV... • Answered on Oct 04, 2011
My sound show is off
Try to install a sound driver
9/14/2011 12:27:49 PM • Intel D915GAV... • Answered on Sep 14, 2011
2answers
I want intel d915gav ethernet
You can download your driver for windows XP on this link:
http://downloadcenter.intel.com/confirm.aspx?httpDown=http://downloadmirror.intel.com/8659/eng/PRO2KXP.exe&lang=eng&Dwnldid=8659
Just, accept the license ageement and download will start.
If I could be of further assistance, let meknow. If this helps or solves the issue, please rate it and give a testimonialfor my response.
9/3/2011 5:25:39 AM • Intel D915GAV... • Answered on Sep 03, 2011
DFDDFD
> DFDDFD
Double
Fast
Device
Driver
For
Diskettes
8/2/2011 10:56:16 PM • Intel D915GAV... • Answered on Aug 02, 2011
Intel D915GAV Motherboard Logo
152 questions posted
Top Intel Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Intel Computers & Internet
Most Popular Question
sound driver win 7
  • Computers & Internet
