20 Most Recent
Kodak EasyShare P880 Digital Camera Questions & Answers
Camera error#
What type of error does it show? How does it react? More info please!
Can i update camera firmware through a printer dock?
Kodak does not suggest a firmware upgrade through a printer dock. Instead, they recommend using an SD card (memory card).
First:
- Click Download, then save the firmware file to your computer desktop.
- Double-click the *.exe file. When the WinZip Self-Extractor screen appears, select a folder or accept the default location, then click Unzip. The firmware file unzips to the specified folder.
- Note the location of the *.FW file, then close the WinZip Self-Extractor.
Instructions:
- If you have pictures/videos on your camera's internal memory or on the memory card, save them to your computer.
- Ensure that your camera batteries are fully charged.
- Turn off your camera.
- Insert the memory card into your computer or into a card reader attached to your computer.
- Verify that the memory card has at least 100 MB free space.
- On your computer, select the removable drive associated with the memory card or card reader.
- If a System folder does not exist on the memory card, create one. From the removable drive window, select File > New > New Folder, then name the new folder System.
- Copy the *.FW file from your computer into the System folder.
- Remove the memory card from your computer or card reader, then insert it into your camera.
- Turn on your camera, then follow the instructions to begin the firmware upgrade. The upgrade takes approximately two minutes to complete.
- When "Upgrade was successful" appears on the LCD, select Delete Upgrade File to delete the firmware file from the memory card.
- Turn off your camera, then turn the camera on to activate the new firmware.
Two problems with my P880,
Normal behaviour for the P880!Look here for an explanationhttp://forums.dpreview.com/forums/read.asp?forum=1011&message=20201983
Kodak easyshare p880 camera
use WD40 or contactspray around the powerswitch after removing the battery.then work the switch for a number of times
Turns off by itself
I have tried numerous avenues including email solutions from Kodak and possibility of reinstalling the firmware but none worked. I fully believe the problem lies in the power switch - it is no longer making proper contact when in the on position. The only way appeared to be to have it repaired by a camera repair depot preferably one that also happens to be authorized by Kodak. The repair cost estimate given to me was $70 Canadian. Unfortunately I reported the problem after the warranty period had expired and like most corporations today, Kodak absolutely refused to foot any of the bill once the warranty period is over. I have no good reasons to keep Kodak on my list when shopping for another camera. P880 was a great camera except for the unexpected switching off and Kodak has not made a replacement camera with the same degree of sophistication.
My Kodak easyshare p880 will
Go to www.dpreview.com and Kodak Talk. Search the forum for "P880 Power Switch problem".
Problem can be solved with the use of WD40. Read the solution on Kodak Talk first!!!
Hope you'll succeed!
Gr. Mart
Kodak P880 camera won't autofocus. I bought a used
Hi mfkcolumbus,
Did you check the firmware version? If it's not v. 1.02, then get it at the Kodak support site and flash that firmware to your camera. If it is 1.02, then you may try to reflash that same firmware. Sometimes this helps strait'n out things.
Hope this helps.
Gr. Blackbear
Kodak EasyShare P880 not getting
Hi stanleychen1,
Did you upgrade the firmware to v.1.02? This should solve this problem. The upgrade can be obtained at the Kodak support site.
Hope this helps.
Gr. Blackbear
Lens error wont open
Fixing your problem could be as simple as cleaning the battery contacts
in the camera, or the solution could be a lot more complex and
expensive. Here's a link to the Kodak Help Center - it provides a
simple Q&A format to diagnose the problem and propose a solution.
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
It reads internal memory but not a memory card
Download the pics from the internal memory if you want to save them. Then:
1. With the memory card out of the camera, go into the menu and find "format"...follow the on-screen instructions.
2. Go into the menu and find "reset"...follow the on-screen instructions.
3. Making sure the slide switch on the side of the card is in the unlocked position, insert the card.
Everything should work now.
