Lexmark X Office Equipment &... • Uploaded on Aug 29, 2013
Try to re-seat the cartridges in the printer. Open the printer cover > remove the cartridges > close the printer cover > re-brick you printer by pulling out the power supply - black box behind the printer where the power cord is plugged in, and re-plug after 10 seconds. When the printer turns on, reinsert the cartridges and close the cover. Try to print a document again to verify that the problem is fixed.
If that doesn't help, the problem could be due to a clogged print cartridge nozzle. Please follow the steps below to fix print quality issues with your model:
From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a page forcing ink through to clean the print cartridge nozzles.
Clean Cartridge Nozzles (Solution Center):
1. Go to Start, Programs(Windows
XP: All Programs), Lexmark 3300 Series, Lexmark Solution Center.
2. Click the Maintenance tab.
3. Click Clean to fix horizontal streaks.
4. Click Print. A cleaning page prints, forcing ink through the clogged
nozzles to clean them.
5. Print a document again
to verify that the print quality has improved.
6. If you are still not satisfied with the print quality, follow the instructions in this article How to Clean the Print Cartridge Nozzles and Contacts Manually.
62 questions posted
1,487 Questions
1,353 Questions
1,277 Questions
961 Questions
741 Questions
