20 Most Recent
Linksys BEFW11S4 Wireless-B Broadband Router (12503024) Questions & Answers
Is there softwear for this
No, no software but there is a User Manual.
You will need to locate what Version you have (there are 4.) via the drop-down selection before you can download your User Guide here
Linksys Support
QUIERO CAMBIAR EL PASSWORD
Hello Jose,
Please try the below steps for changing the Linksys router's administrator password
Step 1:
Access the router's web-based setup page. To do this, open a web browser and enter the IP address of the router on the Address bar then press [Enter].
Step 2:
Click on the Administration tab. Enter the new password in both the Router Password and Re-enter to confirm fields.
Step 3:
Click Save Settings and click the Continue button on the next page.
Thanks
All the best !
I need the WEP security
connect to the router using an ethernet cable log into it and reset the WEP pass phrase in the wifi setup screen
Im trying to hook my
Try: Clarify - the desktop is connected with an ether net cable? Is working? Install router software on desktop to manage router. Trying to connect desktop wirelessly? Wireless card installed? Radio activated? Network detected?
I HAVE A LINKSYS
You dont need an admin account or installation disk to install the Linksys router that you have.
Just get an Ethernet Cable plugged in to 1 of the 4 ports at the back of your router and plug it to your computer.
Then Access your router via your computer by opening Internet Explorer and type 192.168.1.1 to the address bar.
if it would ask you for Username and Password, default should be the one below.
Username:
Password: Admin
As you can see you just need leave the password blank and put admin to the passowrd.
if this password doesnt work just press the reset button at the back of the router for ten seconds and restart the router.
After that try accesing the router again. It should now let you access your routers setup page.
I have not used my
open
a browser window and then type http://192.168.1.0 or http://192.168.1.1
and enter your router settings. change settings including password.
unless you've set it up differently and actually have a username and
password, leave the username space blank and use "admin" as the
password. that's often the default password on a linksys. linksys has a
great support page. they have the drivers, manuals, the works.
your specific page for the drivers and the manual for your router which includes specific info including password, setup procedures, explanation of the various settings, how to do a hard factory reset, etc. is here http://homesupport.cisco.com/en-us/wireless/lbc/BEFW11S4
Bought wireless router without software
Hi friend,
In order to download the drivers and firmware of your router you may refer to the link http://www.linksysbycisco.com/APAC/en/support
Eneter the model number. Click get downloads and in the next page select the hardware version. You will be able to download the software.
Regards
Chiranjeet
Set up a non wep password...
Hi Friend,
Please follow the steps;
1.Open the router page(192.168.1.1)
2.Enter the username and password(default password is admin and leave the username blank)
3.Click Wireless and then fill the sections as mentioned:
Wireless-Enabled
Wireless Netowrk Name-As per your choice
Wireless Channel-6-2.442GHz
Wireless SSID broadcast-Enabled and click Save settings
4.Click Wireless Security and fill the sections
Wireless Security-Enabled
Security Mode-WPA pres-shared key (as you want non wep password)
WPA Algorithm-TKIP
WPA Shared key-Minimum 8 and maximum 64 digit password
Group Key Renewal-3600 and click save settings
Turn off the router for 30 seconds and turn it on after that. Now you have a non wep secured network
I hope this will resolve the issue.
Regards
Chiranjeet
