20 Most Recent
MSI : MS-7061-020 VIAKM400/A&V&L/SATA Motherboard (MOT73) Questions & Answers
Sir,
i have an msi n1996
I enabled SATA support on my BioStar M7VIZ-SATA MOBO (it is km400 and 8237r, like yours) by first installing the VIA SATA RAID drivers. At this point, Windows recognized the device controller but not the 120GB drive. The problem was that the system doesn't support "newer" SATA drives, so I installed a jumper on the disk drive to set it to "150" mode... SATA version 1 compatibility. After that, Windows immediately recognized the drive and mounted the filesystem.I think it was a Western Digital drive. Other manufacturers have a different name for the same jumper. Also, I read that one type (Samsung?) can only be set to the old SATA standard by getting the drive running in a SATA 2 environment, then using a utility program to adjust the drive's microcode setting.Good Luck to you.
10/21/2011 7:08:23 AM •
MSI :...
Answered
on Oct 21, 2011
I have enable sata in
Good day,try to remove all hard disk, if not try to change the sata cable...thakns
8/17/2011 9:38:11 AM •
MSI :...
Answered
on Aug 17, 2011
I need to know where
Can you go to the MSI website and download the manual, looking at your motherboard usually it can be found at the bottom of the motherboard, usually the right side, also you should see small abbreviations of the connection relative to the pins they are associated to. If you need more help just ask. Thanks Rick.
7/28/2011 5:45:49 AM •
MSI :...
Answered
on Jul 28, 2011
I have MSI K8MM-V
my friend go to bios and chose this option hard disk--- sata IDE..ok? not raid option..i am sure ur problame will be fixed
3/29/2011 6:00:50 AM •
MSI :...
Answered
on Mar 29, 2011
Im install for all driver
HELLO, WHAT YOU ARE TO DO IS TO UNPLUGE ALL PLUGED AND TRY RE-PLUGING YOU WILL SEE THE PROBLEM.
3/25/2011 12:18:46 PM •
MSI :...
Answered
on Mar 25, 2011
Drivers
Type 1.Live Update Online
Thanks to our brand new online update service, now we
can provide you a faster automatic download for your MSI products. Use
the time saving service to update your product with safe and ease.
This online search supports the following MSI product lines and items:
Mainboards: Drivers/BIOS versions/Utilities; Graphics Cards: Drivers/BIOS versions/Utilities; Barebone: Drivers.
How to use?
NOTES:
- MSI Live Update Online must use Microsoft® Internet Explorer 5.0 and
above versions, OS requires Windows® 98SE/ME/2000/XP/Vista/7 32bit.
- MSI Live Update Online uses Microsoft® ActiveX technology, please modify
your ActiveX settings to ensure the proceeding of the automatic analysis and download.
If your browser has installed Toolbar plug-ins, which might affect the normal operation
of MSI Update Online.
- Please check your Toolbar-related settings to ensure the proceeding of the update service.
12/22/2010 3:55:02 AM •
MSI :...
Answered
on Dec 22, 2010
Solved
Hello there:
i am glad to hear this thanks a million for using fix ya
best regards michael
11/18/2010 12:39:46 AM •
MSI :...
Answered
on Nov 18, 2010
I Just installed a new board ASUS MS 7061 in to HP
Just a couple of suggestions to get you started.
Make sure the 4pin cpu connector is plugged in, and the memory is properly seated. Please post back if the problem is unresolved.
Thanks
2/3/2010 12:30:20 AM •
MSI :...
Answered
on Feb 03, 2010
Ms-7061 msi motherboard will not install win xp with sata drive
The problem is that your version of XP does not have SATA drivers and therefore does not recognise your new drive. Vista does.
If you Google the problem you will find many solutions on how to rectify the situation.
Basically, you have to make a floppy disc with the correct drivers for your Motherboard's hard drive controller. Then, when you launch your Windows XP installer, it will ask you a question about needing to install 3rd party drivers. Yes is your answer. Tap F6 to ensure that the installer doesn't skip.Insert the floppy disc and then after the drivers are loaded, the installation will proceded normally.
The other alternative is to leave your existing XP installation in place and add the new disc.
Later you can clone your old disc onto the new drive and then remove your original disc.
2/11/2009 6:22:28 AM •
MSI :...
Answered
on Feb 11, 2009
How do i download MSI N082 graphics driver
To get the MSI N082 graphics driver:
1. Find your graphics card model. Note down the model number.
2. Go to MSI's website.
3. Look for the support or downloads tab and click on it.
4. Use the search or menu options to find drivers for your specific graphics card model.
5. Download the driver package.
6. Run the installer file once the download is complete.
