20 Most Recent NEC DTU-32D-2 Corded Phone Questions & Answers
Manual for DTU-32D-2
If you go online and type in your system type/user guide/PDF, some service companies have the user guide online for download.
5/7/2014 4:48:43 AM • NEC DTU-32D-2... • Answered on May 07, 2014
Phone is displaying DND (do not disturb)
Do not pick up the receiver press feature button dial 60 press feature button again, at least this worked for me.
3/17/2009 7:47:06 PM • NEC DTU-32D-2... • Answered on Mar 17, 2009
I have a red flashing light on a NEC DT400, it is the reception ext key. How do I cancel it out?
To cancel the red flashing light on the NEC DT400 associated with the reception extension key, follow these steps: Hold the Exit Key: Press and hold the Exit key. Select MW (Message Waiting): While holding the Exit key, select the MW (Message Waiting) option. Choose "All": From the available options, choose "All". This should help resolve the issue related to the reception extension key. If you encounter any further difficulties, consider referring to the NEC DT400 User Manual or contacting your NEC Authorized Supplier for additional assistance.
4/22/2024 6:10:06 PM • NEC Lands Phones • Answered Yesterday
How can i fix message 14 on nec sl1000
To address Message 14 on the NEC SL1000, follow these steps: Hold the Exit Key: Press and hold the Exit key. Select MW (Message Waiting): While holding the Exit key, select the MW (Message Waiting) option. Choose "All": From the available options, choose "All". This should help resolve the issue related to Message 14. If you encounter any further difficulties, consider referring to the NEC SL1000 User Manual or contacting your NEC Authorized Supplier for additional assistance.
4/22/2024 6:06:23 PM • NEC Lands Phones • Answered Yesterday
I need a manual for NEC BDS 22-BTN 80573 66240705 it's an older telephone.
If it is available, it will be here, or ask NEC Support direct. https://www.google.com/search?q=nec+bds+22-btn+manual The Google search query for this is simply NEC (model) manual but you seem to be putting '22 BUTTONS' mixed in with the model number. The most effective search queries are the shortest ones. https://www.google.com/search?q=nec+bds+80573+manual ..
4/3/2024 4:22:44 PM • NEC Lands Phones • Answered on Apr 03, 2024
How can i access voicemails on NEC phone system model P4WW-12TXH-B-TEL(BK) please
You model number is the number of the phone that goes with the SL1100 Phone System. It have to be set up in the Management System first to be able to access from the phone. The designation (BK) signifies the phone is Black as opposed to (WT). The NEC IP4WW-12TXH-B-Tel Phone 1100061 is a phone designed for the SL1100 system. The 1100061 is a 12 button phone featuring a full duplex speakerphone, headset jack, backlit display, and more!
NEC SL1100 Phone IP4WW-12TXH-B-TEL (BK) 1100061 ...
NEC SL1100 Telephone & Voice Mail User Guide
Interconnect Services https://www.interconnectservices.com > 2015/12 PDF TO ACCESS VOICEMAIL. ? From your phone press VM soft key. Follow prompts ... ? From outside the office, dial main number. When the voice mail system answers, ... 2 pages Missing: bk) ‎' Show results with: bk)
NEC SL1100 Phone System Manual
Rhode Island Telephone https://www.ritelephone.com > uploads > 2019/04 PDF ..
2/8/2024 10:53:36 PM • NEC Lands Phones • Answered on Feb 08, 2024
How do I get the blinking light off NEC phone?
speaker 771 or speaker 773
10/24/2023 10:45:28 PM • NEC Lands Phones • Answered on Oct 24, 2023
My Extension Line Keeps flashing NEC DT400
Try 751 as the code. You can also try unplugging the main control box at the end of the workday for 10 minutes and plug it back in. This might remove temporary programming.
NEC DT400 Phone Manual
Rhode Island Telephone https://www.ritelephone.com > uploads > 2019/07 To Program a Line key as a Programmable Function. Key: 1. Press the Speaker key. 2. Dial Service Code 751. 3. Press the Line Key to be programmed. 72 pages I have never heard of this 'hunt group' feature before. https://www.google.com/search?q=nec+dt400+programming+guide ..
9/13/2023 12:16:33 AM • NEC Lands Phones • Answered on Sep 13, 2023
NEC IP2AT-12TXD phone. How can I forward all calls immediately to my mobile?
Page 10 of the manual which is the second sheet down on the right hand side. https://manualzz.com/doc/2126665/nec-ip2at-12txd-phone-telephone-handset-black---topazmltu...
How to Forward Calls on an NEC Phone
Rhode Island Telephone https://www.ritelephone.com > how-to-forward-calls-o... Press Speaker · Dial 741 · The display will read: 1 to set or 0 to cancel. Press 1 and enter the extension number that you want to forward your number to. · Press ... .. NEC Videos
8/15/2023 4:15:04 PM • NEC Lands Phones • Answered on Aug 15, 2023
HOW TO FIX TIME AND DATE FOR TELEPHONE SET NEC MODEL IP2AP-12TXD TEL2(WH)?
There is a post here: https://sundance-communications.com/forum/ubbthreads.php/ubb/showflat/Number/242170/Searchpage/2/Main/42698/Words/time/Search/true/time-change-this-weekend#Post242170 SV8100 and IPKII systems From any display phone With the phone hung up [idle] Press SPEAKER Dial 728 Using a 24 hour [military] format Dial 2 digits for the hour Dial 2 digits for the minutes Press SPEAKER to enter the change / end Only the InMail voice mail clock is controlled by this clock setting. All other voice mail products will have a separate clock. Electra 8/24, PROI, PROII, Elite, & Elite IPK Systems From the station connected to port 01 or 02 of the system [Usually that is the attendant phone; ext 10, 11, 100, 101] With the phone hung up [idle] Press FEATURE [or FNC] Dial 9 Press # Enter the hour and minute via the dial pad Press RECALL to change to am / pm as needed If you only need to change the clock setting Press FEATURE [FNC] to end If you need to change the date as well continue Press HOLD Press RECALL [repeatedly if needed] to scroll through to select the day of the week Press # to move the cursor to the day of the month field Enter the day of the month via the dial pad Press RECALL [repeatedly if needed] to scroll through and select the month Press # to move the cursor to the year field Enter the last 2 digits of the year via the dial pad Press FEATURE [FNC] to end Cheers from Atcom https://atcomsystems.ca
4/18/2023 8:54:52 PM • NEC Lands Phones • Answered on Apr 18, 2023
Lands Phones Logo
17 questions posted
Top NEC Lands Phones Experts
ADMIN Andrew
ADMIN Andrew
Don A
Don A
RAJA NADEEM AKHTER
RAJA NADEEM AKHTER
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
View Most Popular
NEC Lands Phones
  • NEC Lands Phones
Most Popular Question
phone displaying dnd not disturb
  • Lands Phones
