20 Most Recent RCA DRC620N Portable DVD Player Questions & Answers
Portable DVD now only plays in black & white
If you cannot get it to work, the drop did the damage. Sorry.
9/9/2017 4:41:16 PM • RCA DRC620N... • Answered on Sep 09, 2017
2answers
Portable DVD PLAYER: I don't get any audio. I'm
Maybe it has a failure in the audio amplifier, if there's no sound even with headphones or the internal speakers, if there's audio only with headphones.
1/12/2017 3:13:01 AM • RCA DRC620N... • Answered on Jan 12, 2017
2answers
Adapter plug size
Wal-Mart ectronics dept. has an "Universal DC Adapter Kit" it will have various size adapter plugs and a variable setting to adjust DC Voltage. It also should have a switch to set the polarity. I used mine to power several different devices. It was well worth the money I spent as opposed to buying a actual DC Adapter. Subsequently, the kit from Wal-Mart was far cheaper than the real deal.
-marshall.
Albuquerque, NM
5/31/2009 7:24:56 PM • RCA DRC620N... • Answered on May 31, 2009
RCA DRC620N portable dvd
Inside your dvd player there is a flat flexible cable running from the dvd player to the lcd screen. I opened mine up, and saw that the opening and closing of the lcd screen has caused this cable to pinch. I didn't check for continuity of each little wire in the cable (there's about 20 of them), but I suspect that this is where the problem is. In a design where we are forced to flex and bend this cable each time we open up the dvd player, I guess we shouldn't be surprised that the cable eventually gives out. Maybe replacing the cable would work, but I just use mine as a DVD player in my kids room now, and send the output to the TV.
11/25/2008 3:53:57 AM • RCA DRC620N... • Answered on Nov 25, 2008
Wrong region
open the control panel then double click system, click the hardware, open the device manager then click (+) of dvd rom drives right click to open the properties. you can see the region, you can now change the region according to what country you are. you have only 3 changes to make with the region
12/5/2007 5:31:42 AM • RCA DRC620N... • Answered on Dec 05, 2007
2answers
Powers up but shuts down when play button is pressed RCA YLG43E
Try to check the power supply output side where anything could came into contact with positive and negative line for which when you press play button then it shuts down.
3/25/2024 6:44:15 PM • RCA Televison &... • Answered on Mar 25, 2024
Black and white screen only on DSTV?
RCA video cables handle analog signals. HDMI cables carry digital video signals. You need a converter. If you are using a component video converter, check if you swapped two of the three RCA video cables. (There are some A/V projectors that can do the translation of RCA and HDMI internally. Most TVs do not.) I hope this helps. Cindy Wells (One of my family's TVs used a dongle to condense the analog video signal to a single port, swapping blue and green gave a black and white output, IIRC.)
3/24/2024 11:03:58 PM • RCA Televison &... • Answered on Mar 24, 2024
I have an RCA re20qp80 remote that the mute button doesn't work
Most modern tv remotes are not normally designed to be repaired. You will possibly need to replace it. there are plenty of cheaper after market version that will do the job just as well. Your other option, and yes I know this is a silly answer, when you want to mute the TV is to simply press the volume down button to zero then turn it back up when you want sound.
2/23/2024 10:21:26 AM • RCA Televison &... • Answered on Feb 23, 2024
2answers
How to connect rca vr667hf to tv
you will need to rind RCA to whatever input is on your tv google RCA to HDMI copy and paste link for manual https://www.manualslib.com/manual/313476/Rca-Vr677hf.html#manual
2/18/2024 4:51:27 PM • RCA Televison &... • Answered on Feb 18, 2024
2answers
I Want code list for RCA 4- device universal remote
You need the TV codes not the remote ones. I would use the Remotes code search feature as the Sanyo has allot of codes and you may spend hours going through them. Sanyo remote codes 0154 0208 0157 0280 0484 0292 0721 0011 0036 0045 0370 0068 0339 0072 0216 0104 0217 0145 0146 0156 0555 0381 0412 0009 0508 0544 0163 0799 0037 1154 0108 0159 0556 0486
2/2/2024 11:35:38 PM • RCA Televison &... • Answered on Feb 02, 2024
Where is the fuse located on a rca flat screen tv
The fuse on an RCA flat screen TV is typically located on the power supply board near one of its corners. The power supply board is the board with an array of capacitors, resistors, and heat sinks on it . The fuse is a small cylindrical tube with metal caps and is relatively small compared to other components on the board . If you have never seen a circuit board before, finding the fuse may be tricky. You can consult the user manual for your TV if you need help locating the fuse . TV Fuse Replacement Guide: Locating and Replacing Your TV Fuse - PointerClicker.com Replacing the fuse should be done with caution, especially if it is soldered to the board, as errors could lead to costly damage. You can check if the fuse is blown visually or with a multimeter-like tool. If you are unsure about how to replace the fuse, it is best to seek professional help.
1/21/2024 8:13:40 PM • RCA Televison &... • Answered on Jan 21, 2024
What is the code for remote control for RCA model# RT 1971-AC
Better idea https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote
Replacement Remote Control for RCA DETG160R ...
Amazon.com https://www.amazon.com > Replacement-DETG160R-... Replacement Remote Control for RCA DETG160R DETG190R RT1971-AC RLDED3932ARK LCD LED HDTV TV - ( Compatible Model: DETG160R ) ; Controller Type. Button Control. US$32.99 · ‎In stock
RCA RT1971AC Replacement Remote
Remotes.net https://www.remotes.net > products > replacement-rem... If your original RCA remote has died, been destroyed or lost, or has simply stopped working, this replacement RCA remote can be the solution to your problems. US$34.90 RCA Universal Remote Codes:
  • The TV codes are: 000, 006, 011, 019, 027, 034, 038 and 044.
  • The VCR codes are: 000, 005, 007, 008, 028 035, 037, 054 and 069.
  • The cable box codes are: 000 and 027.
Apr 26, 2023
RCA Universal Remote Codes List 4 Digit - GenTwenty
12/27/2023 12:47:10 AM • RCA Televison &... • Answered on Dec 27, 2023
Rca remote r26211 code for trutech tv dvd
Better to get a Facsimile Remote, a copy made for the unit. It is unlikely, you can input codes to work both applications in a combined set.
TruTech TV universal remote control codes (3, 4 and 5 digit)
eliztech.com https://www.eliztech.com > remotes > codelists > trutec... Universal remote codes for TruTech TV sets - 3 digit, 4 digit and 5 digit codes.
My mom has a Trutech combination TV/DVD, about 20 ...
JustAnswer http://www.justanswer.com > TV Problems Feb 6, 2013 - There are very few universal remotes that will operate a tv/dvd combo and of ten if you find a code then the tv a dvd have separate codes. 1 answer · Top answer: Jack : Hi and welcome to justanswer. To answer your question; There are Make sure you use the FULL Model Number for it.
TRUTECH TV Replacement Remote
Remotes.com https://www.remotes.com > trutech-remote-controls-s Replace new & discontinued remote controls for TRUTECH devices with fully programmed remotes from our online store. Enjoy low prices and fast shipping.
Trutech Remote for sale
eBay https://www.ebay.com > ... > Remote Controls Sort ; 2PCS Remote Control For TruTech KLV3170 LCD Drop Down TV Built-in DVD Player · $13.83 ; TruTech A60P0315 Remote Control Genuine OEM TESTED · $3.00 ; Original ...
Trutech Remote Control
Amazon https://www.amazon.com > trutech-remote-control > k... GE Universal Remote Control for Samsung, Vizio, LG, Sony, Sharp, Roku, Apple TV, TCL, Panasonic, Smart TVs, Streaming Players, Blu-ray, DVD, 4-Device, ...
12/20/2023 1:17:20 AM • RCA Televison &... • Answered on Dec 20, 2023
I dropped my RCA remote control, how can I reestablish connection with Magnovox tv?
Check that the batteries haven't become disconnected. Do the Smartphone camera test to see if it is transmitting a signal. If it isn't, buy a remotes specially made for the Magnavox rather than an RCA Universal. Google Magnavox (model) remote control replacement. https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote ..
11/30/2023 4:26:09 PM • RCA Televison &... • Answered on Nov 30, 2023
My old Panasonic TV set has no video RCA slot. Only audio R and L slot available.
tv is not a smart tv, may have to replace it.
11/27/2023 3:30:48 PM • RCA Televison &... • Answered on Nov 27, 2023
How do I program an RCA TV with a Panasonic universal remote control e u r 7722x40
https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote RCA Universal Remote Codes: For the RCA Universal Remote, there is a total eight different codes for RCA TV's and nine for VCR's. There are two different codes for cable boxes:
11/19/2023 5:44:36 AM • RCA Televison &... • Answered on Nov 19, 2023
Will RCA DRC8335 finalize discs recorded on RCA DRC8312 ?
Depends on the software you are using; ExpressBurn, Movavi etc will finalize.
11/13/2023 5:50:11 PM • RCA Televison &... • Answered on Nov 13, 2023
How to add external rca jacks to the output
To connect your audio receiver to your Proview 3200 flat screen TV, you can use RCA cables. Here are the steps: Locate the RCA jacks on your TV and audio receiver. One jack is white, and the other is red. Plug the white RCA cable into the white jack on the TV and the red RCA cable into the red jack. Reversing them will cause the stereo signal from the TV to be incorrect. Take the other end of the RCA cables and plug the white and red ends into an available RCA input on the back of your audio receiver. If your TV doesn't have RCA jacks, you can use a digital-to-analog audio converter to connect your TV to a 5.1 audio system that has only RCA inputs 1. You can follow these steps: Unbox the digital-to-analog converter. Connect the optical cable to the converter. Connect the RCA cable to the converter. Connect the other end of the RCA cable to an available corresponding analog audio input on your audio receiver
10/30/2023 4:08:01 AM • RCA Televison &... • Answered on Oct 30, 2023
2answers
Adjusting the brightness on the tv for a rca tv
make sure you have the original remote for the Tv and follow the steps below RCA Color TV User Manual Picture Settings
8/31/2023 4:35:34 AM • RCA Televison &... • Answered on Aug 31, 2023
RCA DRC620N Portable DVD Player Logo
7 questions posted
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • RCA Televison & Video
Most Popular Question
adapter plug size
  • Televison & Video
