20 Most Recent Maytag Dual Cool 25 cu. ft. Side-by-Side Refrigerator MSD2556 Questions & Answers
2answers
Which way do you turn the dial for changing temperature control to make it quit freezing all our food
If there is a off position, That will be the direction to turn it higher. Make sure the seal on the door is working properly. It can cause ur problem If you need further help, reach me via phone at https://www.6ya.com/expert/gary_9c859f4aa7e5ab10
3/3/2018 2:06:19 AM • Maytag Dual Cool... • Answered on Mar 03, 2018
Maytag Dual Cool Fridge is constantly running and the freezer side is hot
Check to see if the compressor is running and is it hot?
9/25/2014 4:29:39 PM • Maytag Dual Cool... • Answered on Sep 25, 2014
Crusher control rod and bracket
I wouldn't replace this unless you're a repairman. This isn't a circuit which can cost you. You should call the Maytag repairman? Is your warranty still in tact? I buy 5 year service plans as I used to sell and install appliances for Sears. A circuit board can cost you 4 times the service plan.
9/9/2014 12:59:26 AM • Maytag Dual Cool... • Answered on Sep 09, 2014
Water dispenser
I would check for a bad MicroSwitch
10/29/2013 2:10:09 PM • Maytag Dual Cool... • Answered on Oct 29, 2013
Ice maker is overfilling
Here is the service manual for that ice maker. Look at page 26 for the water volume information.
11/27/2012 10:18:44 PM • Maytag Dual Cool... • Answered on Nov 27, 2012
Defrost
I am not sure about the question you are asking but yes the model MSD2556 Click here=> MSD2556AES Controls location 13 in that photo is your=> 61005988 Defrost Control Board11_21_2012_5_27_57_pm.jpgA parts list with this part can be found on page 2 and 3 of the MSD2556AES Parts Manual PDF for other manuals click HEREIf you have questions please let me know, Thanks Sea Breeze
11/21/2012 5:47:36 PM • Maytag Dual Cool... • Answered on Nov 21, 2012
ICE MAKER NOT GETTING WATER FOR ICE BUT THE DOOR UNIT WORKS
I had this problem and eventually traced it to the water freezing in the fill tube in the freezer.  I defrosted the tube and no more problem
7/15/2012 5:01:57 AM • Maytag Dual Cool... • Answered on Jul 15, 2012
Model MFF2557HEW, serial 12681636JE.
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help go here:
http://www.applianceaid.com/procedures.html
MORE
TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
9/11/2011 7:18:49 PM • Maytag Dual Cool... • Answered on Sep 11, 2011
Hi, I have a Maytag
Hello, welcome to FixYa.
Based on your post I understand you have a problem with a Maytag fridge, specifically the ice bucket & rod/metal arm.
The metal piece you're inquiring about I believe is the image I've pasted below, correct ?
If so that piece is designed to hold the metal rod to the bottom of the ice bucket as you suspected. I've used an arrow to point to where it should simply "clip" into place and support the rod, as shown here...
You will likely need to place the rod through the hole in the support bracket and then "clip" it to the edge of the bucket. I Hope that helps, I will watch for your reply and we can go forward from here. Thank you for visiting FixYa for your inquiry.
Regards,
Macmarkus :)
9/3/2011 3:18:57 AM • Maytag Dual Cool... • Answered on Sep 03, 2011
Freezer section is plenty cold
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
7/10/2011 3:47:00 AM • Maytag Dual Cool... • Answered on Jul 10, 2011
0answers
Hello, the refrigerator side is not
heatman101
6/12/2011 6:38:49 PM • Maytag Dual Cool... • Answered on Jun 12, 2011
My refergerator / freezer is not working. The fan
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.If your refrigerator is running but warm, then...Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...Refrigerator Condenser Coil Cleaning Refrigerator RepairRefrigerator Troubleshooting Refrigerator CompressorRefrigerator Compressor Start Capacitor and Start RelayRefrigerator or Freezer not Cooling or Getting Coldheatman101
1/30/2011 1:49:28 AM • Maytag Dual Cool... • Answered on Jan 30, 2011
No cooling in the refrigerator or freezer, coils
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
10/29/2010 1:12:23 PM • Maytag Dual Cool... • Answered on Oct 29, 2010
Maytag side by side fridge keeps making a rattling noise
See if the noise is coming from the compressor. It's around back behind the cardboard cover. If it is That's usually mounts inside the compressor. It could still last awhile so if you can put up with the noise just wait for it to quit before replacing the compressor or getting a new fridge.
10/20/2010 4:20:47 PM • Maytag Dual Cool... • Answered on Oct 20, 2010
ICE MAKER NOT WORKING HELP
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
hfhj
9/30/2010 2:38:40 AM • Maytag Dual Cool... • Answered on Sep 30, 2010
Refrigerators Logo
56 questions posted
Top Maytag Refrigerators Experts
vince
Johnny 1000
Jesse Walters
Jesse Walters
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Maytag Refrigerators
Most Popular Question
maytag
  • Refrigerators
