20 Most Recent Samsung SyncMaster 940MW 19" LCD Monitor Questions & Answers
2answers
Hi, I need schematic diagram for IP-48135 T board....
The schematic diagram is going to be very hard to get. We do repairs on this model. What information do you need? The most common problem is the capacitors on the power board. You can find this repair guide at: http://www.ccl-la.com/blog/index.php/repairing-the-samsung-940mw-lcd-tv/ If you need other information then let us know at: [email protected] and we will get glad to assist you in the repair.
CCL_Tech
Corporate Computer
www.ccl-la.com
8/7/2021 10:56:43 AM • Samsung... • Answered on Aug 07, 2021
I have a SyncMaster 940NW
Right click on desk top and get the menu for changing screen resolution.
8/21/2017 1:55:10 PM • Samsung... • Answered on Aug 21, 2017
940mw vertical sync instability
Try another monitor to be sure it is the monitor not the computer. If it is the monitor you need to take it to the repair shop. Be sure you are operating it in the proper range.
3/7/2015 8:22:08 PM • Samsung... • Answered on Mar 07, 2015
Why do I have no signal on the Samsung syncmaster 940 mw tv
Check your cable connection on both ends. Try to change the cable.
10/19/2014 8:40:34 AM • Samsung... • Answered on Oct 19, 2014
0answers
Won't turn on no power
You more than likely have bad capastors or diodes that will require taking the monitor apart then the parts replaced they will have to be soldered in and a small solder gun will be needed to keep heat as low as possible so the board doesn't get damaged. Use only japanese made gold rated parts
3/18/2014 12:40:01 PM • Samsung... • Answered on Mar 18, 2014
Dvi connection to ps3
try to hold the power button for like 6 seconds until u hear a beep...
it will reset the display and adjust it to ur monitor...
hope this helps
1/9/2014 2:07:02 PM • Samsung... • Answered on Jan 09, 2014
Pc screen will not come on
HI,Check you power port.Check it Power Cable.If Monitor not open then may be monitor damage. If PC ask then SMPS check it. Because all power supply to SMPS. Next to check it mother board power come or not. Then RAM slot check, and checking carefully. One time all power section and connector disconnect and some time wait and again proper way connect all device. May be solved you problem.Thanks..
10/10/2013 4:43:19 PM • Samsung... • Answered on Oct 10, 2013
Help with power/ on
Hello,The normal cause of power up problems is a failure in the power supply. Check out this repair guide that shows how to disassemble the unit, what to look for and how to repair the monitor.http://www.ccl-la.com/blog/index.php/repairing-the-samsung-940mw-lcd-tv/I hope this helps.BuddyMc
3/20/2012 3:43:49 AM • Samsung... • Answered on Mar 20, 2012
3answers
Samsung SyncMaster 940MW will not turn on
There are broken/exploded capacitors on the power plate, it is a 5 Minute job to replace them.
1/8/2012 5:10:55 PM • Samsung... • Answered on Jan 08, 2012
2answers
Ive had my samsung 940mw
monitor led didn't light mean power cable is damaged or monitor you can try
good luck
1/8/2012 5:02:42 PM • Samsung... • Answered on Jan 08, 2012
2answers
Samsung SyncMaster 940MW S Monitor info. availability
Here is a link to the owners manual.
1/8/2012 4:58:39 PM • Samsung... • Answered on Jan 08, 2012
The tv s autostore will not retune
i think in your TV...... design ..... is such that once channels are autostored it cannot be retuned ..... so you try this ...... it may work ......... disconnect tv antenna cable ( or local tv channels cable ) from your TV & then click autostoring (auto tunning ) ..... definitely it will scans (search for channels ) ..... but since no cable is connected no channels will get stored ...... but previously autostored channels will get removed ...... so now again connect your antenna cable or local tv cable & then click autostore ...... it will scan for channels .... like this you can retune ....... but remember again you may get same quality of picture which you got earlier ..... if you want better quality of picture you have to use signal amplifier (increases cables signal's strength - then picture quality improves ) .....
11/5/2011 8:28:04 PM • Samsung... • Answered on Nov 05, 2011
Samsung SyncMaster 940MW 19" LCD Monitor Logo
128 questions posted
Top Samsung Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Jean Thiebaux
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
SyncMaster Samsung
  • SyncMaster Samsung
Most Popular Question
antenna hook up jack 940mw samsung tv
  • Computers & Internet
