20 Most Recent
Samsung HL-R5668W 56" HDTV Questions & Answers
Shaking picture tv samsung 5668
Sounds like The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
12/23/2017 11:30:17 AM •
Samsung...
Answered
on Dec 23, 2017
Just installed a color wheel
May I know what is the initial display on the screen when you get to the Service Menu?
Jdillanueva
9/21/2011 2:15:45 AM •
Samsung...
Answered
on Sep 21, 2011
My TV keeps shutting itself
This kind of symptoms is an indication of faulty either the actuator board or the
thermal fuse(sensor).
First check the resistance of the thermal fuse (it is mounted in small board at the top of the lamp housing), it should be shorted(0 ohms), if you dont have a multemeter, install jumper across the terminal of the thermal fuse and try to power on the unit. If the unit power up, replace the thermal fuse, if not replace the actuator board.
Hope I helped you.
Have a nice day!
Thanks for using fixya.
8/27/2011 3:37:10 AM •
Samsung...
Answered
on Aug 27, 2011
According to the description, the color wheel went
did you install the correct color wheel? Most of the samsungs had retooled bearings in some color wheels and often a jumper has to be installed for the color wheel to work properly. Your wheel should be a BP96-01103A another thing that can happen is the thin brown ribbon cable can get plugged in backwards and will prevent the color wheel from working also. That ribbon only has contacts on one side of the ribbon. I would double check that if the correct color wheel was received for your model.
8/8/2011 6:24:58 PM •
Samsung...
Answered
on Aug 08, 2011
I replaced the color wheel.
hi
have you been checked the fan, if it is not working the dmd board will shut down. at the same time check the lamp ballast if their is a shorted it will cause a shut down. hope this will help you just give response if it works good day thanks.
8/8/2011 6:45:11 AM •
Samsung...
Answered
on Aug 08, 2011
Samsung HLR5668WTV went black, replaced
If the noise is a high pitched whine or even a grinding sound you may have a bad color wheel.
These fail quite often in these sets although it is unusual for a lamp to be associated with it. Put old lamp back and see if same problem. (unless old lamp is shattered)
If it is the color wheel I can tell you how to look at it to see if shattered without taking the set completely apart.
See attached photo of typical color wheel.
If this told you something you did not know, rate this solution as very helpful as I do this here for free.
SD TECH
7/29/2011 8:16:23 PM •
Samsung...
Answered
on Jul 29, 2011
TV only stays on for 15 - 20 seconds, screen goes
This usually indicates that the color wheel, ballast or power supply board is failing. I would suggest calling 1-800-samsung to find the nearest service center. You can waste a lot of money trying to figure this one out on your own.
6/4/2010 9:43:06 PM •
Samsung...
Answered
on Jun 04, 2010
TV made a big popping sound, and then a crackling
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.Here's the instructions to replace it :http://www.fixyourdlp.com/guides/samsung/bp47-00033a.php That crackling sound could be of the color wheel:The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will get color distortion ,black and white picture and sometimes you will hear humming noises. But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs it could be time to replace the lamp.The lamp you need is BP9601073A you can find original here:http://www.discount-merchant.com/Samsung-BP96-01073A-lamp-p/samsung-bp96-01073a-lamp-oem.htm?Click=48173 .Have a blessed one!
4/2/2010 3:30:08 PM •
Samsung...
Answered
on Apr 02, 2010
I have a buzzing sound from the cooling fan when
Most likely what you are hearing is the color wheel that is making all the noise. You would be able to tell by removing the back and checking all the fans first. but the sound of the fans usually comes on just before the color wheel starts up.
I hope this information allows you to resolve this issue.
I am doing this for free.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you cannot rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
Thanks for using FixYa
asnowman
1/28/2010 4:47:55 PM •
Samsung...
Answered
on Jan 28, 2010
Dark picture on lg dlp tv
Did you use a generic replacement? Many TVs have a dark picture after replacing the original lamp with a generic. The other issue I've encountered are TVs that have been exposed to cigarette smoke will develop a dark, discolored picture over a relatively short time.
michtech
2/20/2009 2:13:30 AM •
Samsung...
Answered
on Feb 20, 2009
