20 Most Recent
Samsung Digimax L60 Digital Camera Questions & Answers
Low light
Yes that will happen if your camera is set for automatic.
Set your camera for manual by pressing the menu button.
You will have to tell it all of the conditions manually, such as ASA, lighting, and flash.
You can disable or control the flash by using the buttons located on the rear of the camera.
Delete and view my pictures
To view your pictures, you should press the play button. Next to the right side bottem of the display you find a little button with an arrow to the right. That is the one. After you have pressed that one you are in the play mode. You only see the picture you shot last. To see more pictures you should press the left or right button on the big wheel above the play button.To the right of the play button you find the delete button. it is the button with the +/- sign and the bin right above the button.I don't know where I did find the manual, but a couple of days ago it was still online. see pages 35 41 and 45.
IS THERE A FIRMWIRE UPDATE
Sorry, no. It's a hardware difference, and SDHC cards will only work in devices originally designed to work with them.
I have lost the software
You don't need any special software.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as
Picasa.
Is Samsung digimax L60 compatable
It doesn't matter to the camera what operating system you have on your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Windows Photo Gallery or
Picasa.
Hi, I have lost the
You don't need any special software.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as
Picasa.
Need a patch or solution
Picasa.
Wont connect to pc
Try NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as
Picasa.
Lost CD
You don't need any special software in order to use your camera.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as
Picasa.
USB Connection. When connected to computer camera shuts off or displays USB error.
Picasa.
