20 Most Recent Samsung YP-C1Z MP3 Player Questions & Answers
I connected my mp3 player to my pc, the computer
Try resetting the device it?s usually a small pinhole on the back or side of the device try holding that in for about 10 seconds. Then you need to check and see if the driver that is on your computer still working correctly. Here is how you do that how to fix it if it is not working: 1. Go to the Windows Desktop, click on the "Start" button, and then click "Run" or "Start Search" if you are using the Windows Vista operating system. 2. Type the following text into the text box: 3. "devmgmt.msc" Click OK. 4. Select your computer when the Device Manager window opens, and then select "Action" from the options at the top of the window. 5. Choose the "Scan for hardware changes" option from the drop down menu that appears. 6. Insert any USB device such as a mouse or flash drive into the USB port in question. Now simply check the USB device to see whether it is working in order to test the port. And here is how you fix it if it is not working: 1. Look for the icon named "Computer" or "My Computer" and right click on it and select properties, this will open a window named "System Properties". 2. In the system properties windows click on the tab named "Hardware", and Select "Device Manager". 3. On this window you will see all the devices installed on your computer, look for the device not working properly (printer, dvd rom, keyboard, camera, mp3 player, etc), if there is a bigger problem, more likely you will see a cross by it, or an alert stating there is an issue with it. 4. Right click on the device you where having problems with and select uninstall, it will give you a confirmation, press OK 5. Once the device disappeared from the list, click on the menu bar icon that looks like a computer with a magnifying glass this will cause for the system to scan for any devices not registered and will force the re installation of the device.
11/4/2009 4:48:24 PM • Samsung YP-C1Z... • Answered on Nov 04, 2009
Samsung YP-C1 Need user manual
ineed driver to YP-C1 i cant find it i lost the cd
2/15/2009 4:24:30 AM • Samsung YP-C1Z... • Answered on Feb 15, 2009
R.A
First try resetting it, if that doesn't work, I wonder if it could be a short in the on/off button's circuit....if you're comfortable with doing this, try taking as much of it apart as you can, to clean all contact points, etc.
1/12/2009 6:47:45 PM • Samsung YP-C1Z... • Answered on Jan 12, 2009
Samsung yp-u1 mp3
move the "hold" slider back to its original position.
1/12/2009 6:46:28 PM • Samsung YP-C1Z... • Answered on Jan 12, 2009
I cannot find all the songs on my mp3
They're probably in the wrong format - make sure they're in a format yoru MP3 player accepts.
1/12/2009 6:36:02 PM • Samsung YP-C1Z... • Answered on Jan 12, 2009
YP-C1Z 1GB Samsung MP3 player
Yes it is usually the same cable, try connecting it in a different USB port see if the hardware is recignised.
11/16/2006 1:35:07 PM • Samsung YP-C1Z... • Answered on Nov 16, 2006
0answers
Hi..I have a up z5f and it won't start.. just
try to find the soft ware on the inter net and tranfer it on to the divice
11/6/2013 4:19:37 PM • Samsung YP Audio... • Answered on Nov 06, 2013
Forgot password
If this is about your Google account, click the "Can't access your account?" link on the Google sign-in page.
10/28/2013 5:23:34 PM • Samsung YP Audio... • Answered on Oct 28, 2013
Samsung YP-C1Z MP3 Player Logo
14 questions posted
Top Samsung Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
YP Samsung
  • YP Samsung
Most Popular Question
connected mp3 player pc computer
  • Audio Players & Recorders
