20 Most Recent
Sceptre X9G-NagaIV 19" LCD Monitor Questions & Answers
Sceptre monitor will not turn OFF
The on/off switch is defective. Just plug the monitor into a power strip and turn it off with the switch on the power strip.
10/2/2015 2:39:31 AM •
Sceptre...
Answered
on Oct 02, 2015
Power outage at home. Monitor
pop the back off of it and remove the power board, (it's the one that looks more primitive) look at the solder points on the back of the board for any burns or bubbles....
if not then you need to order a new power suply
2/7/2011 3:28:06 AM •
Sceptre...
Answered
on Feb 07, 2011
Monitor started to show an all bright white
Sounds like a bad monitor, but just to be sure, hook a spare monitor to the computer, if okay! The Sceptre Monitor is the issue, the cause is the main board on the back of the display panel processes in coming video signals to correctly display the content, to repair would not justify the cost, cheaper to replace. Now if both screens show the same problem, it will be the video graphics card in the computer.
1/24/2011 8:00:33 PM •
Sceptre...
Answered
on Jan 24, 2011
I have a sceptre x9g-naga III
Not an expert, but from what Ive read, this is a cfl inverter issue. I had the same problem on my Sceptre. Good luck finding parts. My solution: get another monitor.
9/11/2010 6:21:41 PM •
Sceptre...
Answered
on Sep 11, 2010
Occasionally, when I turn on my computer, my
This could be as simple as the video cable isn't connecting securely. You could try replacing the cable or screwing it tighter. We recently had a red tint on an external monitor for a laptop because the cable was loose; since the laptop moved regularly, screwing the connector to the port on the machine wasn't a convenient solution. The other reasons for an odd tint like that is the video card or the monitor starting to fail. Attaching the monitor to a different computer and seeing if the problem repeats will check if it is the monitor and not the video of the computer.
I hope this helps.
2/17/2010 5:01:15 PM •
Sceptre...
Answered
on Feb 17, 2010
LCD goes black after few minutes
I would suspect the capacitors on the power supply board. Other sites show that power up problems are due to the aluminum electrolytic capacitors on the power supply board being defective. Replacing the four 470uf 25v capacitors (470 micro farad, 25 volt) on the board usually fixes the problem. Sometimes also the two 1200uf 25v capacitors could be the culprit. I suggest changing them all. The price is about $7 for the parts online at Mouser electronics plus $7 shipping. I just fixed mine. I bought two 1200uf 35v capacitors, Mouser part number: 647-UPJ1V122MHD6 and four 470uf 25v capacitors Mouser part number: 661-EKY250ELL471MH2 These are slightly larger than the originals but still fit and they were in stock. You will then have to open the unit (relatively easy) remove the power supply board by removing four screws and disconnecting the connectors (Make a note of wire colors and where the connectors came from before removing). Then you will need to remove the old parts by desoldering them and then solder in the new parts (somewhat easy if you have soldered before)
1/15/2010 8:42:04 PM •
Sceptre...
Answered
on Jan 15, 2010
X9G NAGAIV goes black; can display, but wont.
Took it apart, all the way down to the boards and first examined the capacitors on the power board
. It turns out it was a cracked metallized polyester film cap (C10), not a blown electrolytic capacitor. Ordered a new one and some transitors from DigiKey. Dont know if that is the complete fix, but the cracked cap certainly isnt supposed to be there.
11/11/2009 5:07:13 PM •
Sceptre...
Answered
on Nov 11, 2009
